Solved "Quick Response" button does not work in Kunena Discuss
3 years 9 months ago - 3 years 9 months ago #227508 by lemur
the "Quick Replay" button does not work in Kunena Discuss. When clicked, the response form does not open.
The "Action" / Replay" buttons work.
Kunena 6.0.9.1
plg_content_kunenadiscuss_v6.0.1_2023-01-01
Help, please
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload:
Joomla default template details : purity_III | author: JoomlArt.com | version: 2.0.2 | creationdate: October 21th, 2022
Kunena default template details : Aurelia | author: Kunena Team | version: 6.0.9.1 | creationdate: 2023-02-22
Kunena template params:
Kunena version detailed: Kunena 6.0.9.1 | 2023-02-22 [ Git Repository ]
Plugins: Content - Kunena Discuss 6.0.2-DEV
Modules: Kunena Latest 6.0.2
Signature:
Many thanks to Rich and the other advisors.
Last edit: 3 years 9 months ago by lemur.
3 years 9 months ago #227511 by rich
1. In the backend go to Kunena -> Templates -> mark Aurelia and save as default template.
2 . Remove the incorrectly configured menu item (marked in red)
3. Select an existing target at the correct menu item (marked in green).
Menu Issues
Menu Tips
The following user(s) said Thank You: lemur
3 years 9 months ago - 3 years 9 months ago #227516 by lemur
Thank you so much for your recommendations. I have fulfilled them.
Unfortunately, the problem with the "quick reply" button has not disappeared. I have checked the problem in three browsers.
I attach 2 screenshots.
1) before pressing the button "quick reply"
2) after pressing the button "quick reply". As you can see, in this case a rather large field appears, but there is no possibility to enter text in it and there are no answer and refuse buttons.
Signature:
3 years 9 months ago #227517 by rich
There seems to be a conflict with the bootstrap.css. Do you get an error message with the browser console?
3 years 9 months ago - 3 years 9 months ago #227518 by lemur
Yes. The console shows a terrible "red" picture, the same for the first page of the forum, for the open first post before pressing the button "quick reply" and after pressing the button "quick reply".
The same in text form:
LoginManagerPrompter: Couldn't process supplied URIString: http://gh1 LoginManagerPrompter.jsm:1000:16 Exception { name: "NS_ERROR_ILLEGAL_VALUE", message: "Component returned failure code: 0x80070057 (NS_ERROR_ILLEGAL_VALUE) [nsIFaviconService.replaceFaviconDataFromDataURL]", result: 2147942487, filename: "resource:///modules/PlacesUIUtils.sys.mjs", lineNumber: 226, columnNumber: 0, data: null, stack: "loadFavicon@resource:///modules/PlacesUIUtils.sys.mjs:226:33\nloadFavicon@resource:///modules/PlacesUIUtils.sys.mjs:726:27\nsetIconFromLink@resource:///actors/LinkHandlerParent.jsm:143:28\nreceiveMessage@resource:///actors/LinkHandlerParent.jsm:64:14\n", location: XPCWrappedNative_NoHelper } LinkHandlerParent.jsm:152:17 PushServiceWebSocket: _beginWSSetup: Not in shutdown state! Current state 1 PushServiceWebSocket.sys.mjs:502 TopSitesFeed: Failed to fetch data from Contile server: NetworkError when attempting to fetch resource. TopSitesFeed.jsm:208 Failed to fetch https://spocs.getpocket.com/spocs: NetworkError when attempting to fetch resource. DiscoveryStreamFeed.jsm:425:15 No response for spocs_endpoint prop DiscoveryStreamFeed.jsm:1110:19 Failed to fetch https://getpocket.cdn.mozilla.net/v3/firefox/global-recs?ver…-e88c401e1b1f2242d9e441c4&locale_lang=de&region=DE&count=30: NetworkError when attempting to fetch resource. DiscoveryStreamFeed.jsm:425:15 No response for feed DiscoveryStreamFeed.jsm:1452:17 Referrer Policy: Die weniger eingeschränkte Referrer Policy "unsafe-url" für die Website-übergreifende Anfrage wird ignoriert: https://www.youtube.com/embed/?enablejsapi=1&rel=0&autoplay=0&playsinline=1&fs=1 embed
Unfortunately, I do not have sufficient competence to interpret and use this result.
Signature:
3 years 9 months ago #227520 by xillibit
The javascript errors that you have in the console aren't related to discuss plugin or Kunena.
Do-you have bootstrap 5.x which is right loaded on the pages where the kunena discuss plugin is laoded ?
Time to create page: 0.259 seconds
