Question Custom.less not working after upgrade to 5.1.3
7 years 11 months ago #204926
by ruud
sharing = caring
Replied by ruud on topic Custom.less not working after upgrade to 5.1.3
I have encountered this 'issue' my self several times when upgrading the various kunena versions.
Some version requires the entries in custom.less to start with the kunena identifier #kunena.layout
e.g.
this version automatically applies that identifier so you need to remove it again from the custom.less files
I have no clue as to why this is happening / why this is changed between versions?
e.g.
#kunena.layout .label-nobug {
background-color: #32c032;
.label-nobug {
sharing = caring
- Thank you received: 2542
7 years 11 months ago #204930
by rich
Replied by rich on topic Custom.less not working after upgrade to 5.1.3
I've tested it again now, you're right. Thats was not always so. Therefore I gave in my earlier css proposals always codes such as .layout#kunena .topictitle {color: red; }, otherwise the changes were often only visible with "!important".
This seems the problem now. In principle the custom.less (only since K5.1.5) works now as it should.
7 years 11 months ago - 7 years 11 months ago #204937
by unker
Replied by unker on topic Custom.less not working after upgrade to 5.1.3
Hi rich,
I've just tested it with the 5.1.6-DEV and it is still the same. Nothing from custom.less is implemented.
Joomla 3.9, php 7.1.1
Additional:
I shifted the content from custom.less to custom.css and now everything looks as it should.
I guess this shouldn't be the way, right?
Best Regards
Hartmut
Additional:
Best Regards
Hartmut
Last edit: 7 years 11 months ago by unker. Reason: Additional finding
7 years 11 months ago - 7 years 11 months ago #204944
by rich
In principle it should work with the custom.less. The user ruud has posted the solution (2 messages before).
www.kunena.org/forum/k5-1-support/154334...rade-to-5-1-3#204926
But in principle it's no matter if you use css or less.
The advantage from the custom.less, you need less of the codes. Less codes should bring a better performance for the page.
Example:
If you want change the user color in your custom.css you need
and in the custom.less (when it works correct) should be this enough
Example:
#kunena.layout .kwho-user { color: red; }
Last edit: 7 years 11 months ago by rich.
