Question Custom.less not working after upgrade to 5.1.3
- GJSchaller
- Premium Member
8 years 1 month ago #204029
by GJSchaller
Geoffrey Schaller
Technical Officer
Knight Realms
Custom.less not working after upgrade to 5.1.3 was created by GJSchaller
I upgraded one of my sites to Kunena 5.1.3, and noticed after this was done all of the CSS from Custom.less was no longer being applied. The contents of the file (and the file) still exist, but it doesn't seem to be calling on the Custom file after the upgrade.
Geoffrey Schaller
Technical Officer
Knight Realms
- Thank you received: 2542
8 years 1 month ago #204031
by rich
Replied by rich on topic Custom.less not working after upgrade to 5.1.3
Yes, you're right, it lacks the import for the custom less. I will add it in the bug list.
Edit the crypsis.less and add this code at the last place (red marked).
#kunena.layout {
@import 'variables.less';
@import 'quirks.less';
@import 'general.less';
@import 'editor.less';
@import 'icons.less';
@import 'user.less';
@import 'profile.less';
@import 'categories.less';
@import 'mediaqueries.less';
@import 'twitter.less';
@import 'custom.less';
/* @import 'debug'; */
#kunena.layout {
8 years 1 month ago #204032
by ruud
sharing = caring
Replied by ruud on topic Custom.less not working after upgrade to 5.1.3
sharing = caring
8 years 1 month ago #204034
by rich
Hello ruud!
It's not the same bug. Your solution solves the pointing to wrong location for generated kunena-custom.css
/components/com_kunena/template/crypsis/assets/kunena-custom.css 404 (Not Found)
The problem here:
If you have a custom.less, it needs the import, otherwise the codes will not displayed unless you use for all codes !important at the end.
That's why you need the line @import 'custom.less'; in the crypsis.less
But Kunena 5.1 replaced the complete crypsis.less now also if you have already a custom.less.
Therfore you can't see anymore your customized changes if you upgrade.
The problem here:
7 years 11 months ago #204917
by unker
Replied by unker on topic Custom.less not working after upgrade to 5.1.3
Hi there,
I#ve just updated to 5.1.5 and have the same issue. All my customisations are not applied anymore, it just looks terrible now.
In the crypsis.less the import of custom.less is present.
I would appreciate if somebody has a solution.
7 years 11 months ago #204920
by rich
I've tested it and noticed a strange behavior. If you install the nightly build (on bottom on our download page) it works. If you go back from the DEV version to Kunena 5.1.5 it still works. It seems that this error occurs only during an upgrade.
Try to install Kunena 5.1.5 again, maybe a file would have not correctly installed. If does not help, you can also install the nightly build Kunena 5.1.6-DEV.
But create a backup previously.
