Question 5.0.1 - Crypsis Bootstrap3 Problems
10 years 2 months ago - 10 years 2 months ago #179004 by 810
Crypsis = Bootstrap 2 based template
Crypsisb3 = Bootstrap 3 based template
No, the templates are almost the same, but for a other bootstrap version.
For the default category icon.
Go to backend - kunena - template - select Crypsisb3 - basic settings- default category icon -
glyphicon glyphicon-folder-open glyphicon-big
or
fa fa-folder glyphicon-big
if you use fontawesome
Last edit: 10 years 2 months ago by 810.
The following user(s) said Thank You: virtinsanity
10 years 2 months ago - 10 years 2 months ago #179019 by virtinsanity
810 wrote: Crypsis = Bootstrap 2 based template
or
Now it's all clear thank you very much.
As far as the Category and Profile icons go they are still missing eventhough i made the changes you told. Is it possible that smt causing an override or else ?
Profile icons that shows stuff like status don't show up as well in B3. I'm trying to use Fontawesome and i set as you told me most some has gone back alive. Should i name category icons under each category maybe ? All i can see now is a a thin square next to Categories.
Thank you for bearing me.
Last edit: 10 years 2 months ago by virtinsanity. Reason: Explanation.
10 years 2 months ago #179020 by virtinsanity
Ok now i managed to pop Category icons by through assigning all of the categories a proper icon name, yet i still can't activate Profile Icons set. How may i proceed for profile icons set ?
10 years 1 month ago #179803 by scenium
or
I still automatically added to the end of the code:
icon-big
It turns out the code:
glyphicon glyphicon-folder-open glyphicon-big icon-big
Because of this, the icons are not displayed. How to fix it?
