Question 5.0.1 - Crypsis Bootstrap3 Problems
10 years 2 months ago - 10 years 2 months ago #178903 by virtinsanity
When i try to wirte a post the scroll is getting locked and the page gets non-scrollable when clicked on smileys, provider, maps etc. they are not showing up when i click on them and then the page gets stuck!
To get to more in detail the thing is the reply page is functioning and scrollable until i click on smileys, provider, maps etc button. When i click on the provider etc. buttons neither i see the modals popping and the page gets locked without being able to scroll or anything. Same applies to other stuff like adding image buttons. When i click on them everything is locked up and the page is non-scrollable.
I would provide anything you need.
I hope that you'd help me out.
Thanks in advance.
Last edit: 10 years 2 months ago by virtinsanity.
10 years 2 months ago #178928 by virtinsanity
Btw BETA B3 Crypsis is working like a charm as i just switched to it. I don't know why.
10 years 2 months ago #178929 by virtinsanity
B3 Crypsis is whole lot better in every sense so i selected that for now fyi. All working except the category icons but i don't care about them. :)
10 years 2 months ago #178977 by virtinsanity
Will the problems in normal Crypsis be solved or worked on as i mentioned in my posts here ? Because Crypsis B3 is functioning better yet it's missing stuff, so i would be glad to know if you guys work it on or i don't know things i should do on my end to solve. Please let me know.
Thank you.
10 years 2 months ago #178980 by 810
If crypsisb3 is working correct for you, then you have a bootstrap3 joomla template. So then you need to use the crypsisb3 template.
The following user(s) said Thank You: virtinsanity
10 years 2 months ago #179001 by virtinsanity
810 wrote: If crypsisb3 is working correct for you, then you have a bootstrap3 joomla template. So then you need to use the crypsisb3 template.
Ah ok so from what i understood there actually are 2 templates for now right ? I thought that CrypsisB3 is somekind of a "beta" of the original template yet you will keep on building both of them ? Am i correct to understand this way ? So B3 is actually bootstrap 3.
If so i'm missing B3 Category and User icons in user profile. How may i proceed ? :)
