- Thank you received: 2545
Question Problems after site upgrade to Joomla 4
Joomla 4.x and also Kunena 6.0 the collation should be utf8mb4.
If this is not the case, you must change the collation to utf8mb4.
You can do this either with phpMyAdmin or with the Admin Tools from Akeeba. With Admin Tools you just have to select UTF-8 Multibyte under "Change Database Collation" (it is already preset) and run it. After that (as recommended) click on "Repair & Optimise Tables".
But first create a database backup.
- ProgAddicted
- Junior Member
Collation checked, it's the right one.Joomla 4.x and also Kunena 6.0 the collation should be utf8mb4.
But I noticed this: trying to add a category it throws the error "1054 Unknown column 'parentid' in 'where clause'", but in the Categories table the column name is parent_id
- ProgAddicted
- Junior Member
Done, much better now! Now I can see and use categories and discussions, but there is something else to adjust:Correct is parentid. Please create first a database backup, then rename this column to parentid. Afterwards test your page again.
- the root category is not shown
- any attempt to modify any category, including the root one, ends in error: 0 3 arguments are required, 2 given
- ProgAddicted
- Junior Member
0 3 arguments are required, 2 givenIs there a more detailed error message with debug mode?
Call stack
1 () JROOT/libraries/src/Language/:283
2 sprintf() JROOT/libraries/src/Language/:283
3 Joomla\CMS\Language\Text::sprintf() JROOT/administrator/components/com_kunena/src/Controller/:186
4 Kunena\Forum\Administrator\Controller\CategoryController->internalSave() JROOT/administrator/components/com_kunena/src/Controller/:252
5 Kunena\Forum\Administrator\Controller\CategoryController->apply() JROOT/libraries/kunena/src/Controller/:319
6 Kunena\Forum\Libraries\Controller\KunenaController->executeTask() JROOT/libraries/kunena/src/Controller/:226
7 Kunena\Forum\Libraries\Controller\KunenaController->execute() JROOT/libraries/src/Dispatcher/:143
8 Joomla\CMS\Dispatcher\ComponentDispatcher->dispatch() JROOT/libraries/src/Component/:355
9 Joomla\CMS\Component\ComponentHelper::renderComponent() JROOT/libraries/src/Application/:143
10 Joomla\CMS\Application\AdministratorApplication->dispatch() JROOT/libraries/src/Application/:186
11 Joomla\CMS\Application\AdministratorApplication->doExecute() JROOT/libraries/src/Application/:294
12 Joomla\CMS\Application\CMSApplication->execute() JROOT/administrator/includes/:61
13 require_once() JROOT/administrator/:32
