Question Kunena throwing "Call to undefined method stdClass::get()" error on fresh instal
3 years 9 months ago #227438 by Leen
Are you sure it's Kunena?
set your joomla at Global Configuration tab Server Error Reporting to maxium.
Maybe there will be more rules about error reporting.
And also test it with the original joomla template
Cassiopeia site template
With kind regards
Leen
3 years 9 months ago #227440 by toddjharrison
<p>Hello! Thank you for your response.</p>
Are you sure it's Kunena?[/quote]
<p>No, I'm not, but since this is a fresh install on a new domain and Kunena is the only extension throwing errors, it seemed an expedient place to start.</p>
Already tried that. There's a few warnings about depreciated values on the article pages, but nothing that even hints at anything else. Trying to load the kunena on the front-end still just throws the stdClass error with no other errors present on the page.</p>
Now we're on to something. The forum loads with Cassiopia. I'm somewhat embarrassed that I didn't try that earlier. Sometimes it's hard to see the wood for the trees. :) I'll go ahead and contact JoomlArt and see what they have to say. Not sure what needs to happen with this thread, but mark it closed or whatever needs to happen. Thank you again for helping me troubleshoot this.
Todd
Todd Harrison
Founder: MyUAP Report
3 years 9 months ago #227441 by Leen
quite possibly that with the JoomlArt template
\ Templates: Customize in the html folder
maybe disable there some overrides to test
With kind regards
Leen
3 years 8 months ago #227572 by xillibit
Enable debug mode into Joomla! report configuration panel and set error reporting on maximum if you re try you should get the backtrace with the error. Can-you give please the error with the backtrace ?
