Question Kunena throwing "Call to undefined method stdClass::get()" error on fresh instal
3 years 9 months ago - 3 years 9 months ago #227426 by toddjharrison
Hello!
I'm having some trouble with a fresh install of Kunena on a JoomlArt template.
Site: (currently offline for development)
I have successfully installed the forum from the download link on the Kunena site, so am running the most current version. My Joomla is version 4 and is running the most updated version as well as the most current version of the template.
Joomla! Version:    Joomla! 4.2.7 Stable [ Uaminifu ] 31-January-2023 15:00 GMT
Kunena Version: 6.0.8
PHP Version:    8.2.1
The exact error I'm receiving is:
I have run the Kunena diagnostics and there are no reported errors. I have rebuilt the menu and have received successful messages each time. I have searched Google and while there's quite a few 'stdClass' errors listed, none of them seem to have an empty 'get'.
The site is currently offline as its in development, but that has never been a problem in the past (I've deployed Kunena a ton of times in the last decade or so, and have never encountered this problem).
The template I'm using is Comics by JoomlArt if that info is beneficial to helping troubleshoot this.
Thank you in advance for any help you might be able to give to get this resolved and our project back on track.
Thank you!!
Todd
EDIT: Moderators, please move this to the appropriate category if appropriate, and apologies if I've mis-posted.
Todd Harrison
Founder: MyUAP Report
Last edit: 3 years 9 months ago by toddjharrison. Reason: Requested moderators move the post to the correct category.
3 years 9 months ago #227430 by rich
Have you moved Kunena menu items to other menus? Please create a configuration report.
The following user(s) said Thank You: toddjharrison
3 years 9 months ago #227431 by toddjharrison
I haven't moved the forums to a different menu or menu item. I have just used the menu item alias that is generated on install. And please find configuration report below:
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 128M | Max file upload:
Joomla default template details : ja_comics | author: JoomlArt | version: 1.0.0 | creationdate: September 16, 2022
Kunena default template details : Aurelia | author: Kunena Team | version: 6.0.8 | creationdate: 2023-01-17
Kunena template params:
Kunena version detailed: Kunena 6.0.8 | 2023-01-17 [ Git Repository ]
Plugins: None
Todd Harrison
3 years 9 months ago #227432 by Leen
maybe your php version is too high
kunena and joomla don't work for me with php version 8.2.0 and higher
with php version 8.1.13 everything is ok
With kind regards
Leen
3 years 9 months ago #227433 by xillibit
There are plenty of fixes for php 8.2 in Joomla! 4.2.7 but with Kunena 6.0.x you will have plenty of deprecated messages not tested the install of Kunena with php 8.2
3 years 9 months ago #227435 by toddjharrison
Thank you for the reply. I've swapped PHP down to 8.1 but it's still throwing the
Plugins: None
Todd Harrison
Time to create page: 0.186 seconds
