Solved "recent posts" does nog display all recent posts....
there are a lot of posts missing from that view, this has resulted in us missing a couple of support questions of our members
no matter what i change on the settings (Kunena configuration, frontend, Filter category in recent, and the setting below that) it is NOT correct.
When i choose show categories it shows a number of posts, no matter what i choose in the setting below that (sorry, it is in dutch), and if i choose hide categories, i see other posts, but still not everything!
This is has not been a problem in the past, and around the time the problem occured, i did not do any updates
please help!
With kind regards
Leen
But again, when i change the settings, i get a different result:
but the results don't make sense
EDIT: I hope you can see the images??
EDIT2: removed images
no I only see strange lines and it also took a long time to load so it's better that you remove it.EDIT: I hope you can see the images??
but has anything ever changed eg different php version or setting changed.?
With kind regards
Leen
settings: yes, that is what i tried to show with the pictures
But no matter what i use as settings, i never get all the recent posts complete
i am really not a fan of joomla/kunena but i only took over this forum from someone else (and migrating to other forum software is not that easy it seems)
give a link to it sometimes that can put someone on the right track.
ps
but i don't understand you had some pictures added to this forum but in any way because normally i can just attach some picture in my post.
but then I don't use that button insert in message
but I often choose not to put them in the message but below it.
With kind regards
Leen
