Important Kunena Installation Failed!
10 years 5 months ago - 10 years 5 months ago #176310 by LightStriker
quentaro wrote: Try: uninstall, delete kunena tables in mysql
download package again, install.
The only MySQL entry I can find is cg_kunena_version.
And removing it doesn't change anything to my installation problem.
Last edit: 10 years 5 months ago by LightStriker.
10 years 5 months ago #176335 by xristo
Replied by xristo on topic Kunena Installation Failed!
Try the newest build, worked for me
See this post
10 years 5 months ago #176337 by LightStriker
Look at the first post... 4.0.11_2016_06_05 is the build that is failing for me.
10 years 5 months ago #176360 by xillibit
Try to unzip the kunena 4.0.11 package then install plugin kunena system, check in Joomla! plugins that this one is enabled, then re-try to install the 4.0.11 package
