Important Kunena Installation Failed!
10 years 5 months ago #175887 by LightStriker
Trying to install Kunena v.4.0.11 - 2016-06-05 on a Joomla 3.5.1
It doesn't give much information. The components appears to be there, but trying to go in the dashboard yield the same result as the installation.
The following user(s) said Thank You: xristo
10 years 5 months ago #175898 by xillibit
Try to clean Joomla! cache and re-try the Kunena installation
10 years 5 months ago #175901 by LightStriker
xillibit wrote: Hello,
I just did. Same result.
It's a new website with a clean Joomla installation. The only plugins installed are the JCE Editor and DJ-ImageSlider. Everything else is stock.
10 years 5 months ago #176164 by xristo
Replied by xristo on topic Kunena Installation Failed!
wow, wot a pain... same issue. Completely foobar'd my forums, thanks!
10 years 5 months ago #176296 by LightStriker
Just tried 5.0.0 RC2... Same result.
10 years 5 months ago #176301 by quentaro
Try: uninstall, delete kunena tables in mysql
download package again, install.
