Solved Can't get a language installed
10 years 10 months ago #171986 by jeteran
Thanks.
Ok I tried the first suggestion and still English.
Now I went to backend - extensions - manage - install languages and is empty, even though that the backend is all in Spanish. I tried to search languages but appears nothing.
What I did, after setting up the site, was install the language using the extensions - manage because I cound't found the language there.
10 years 10 months ago #171987 by 810
Replied by 810 on topic Can't get a language installed
try to clean cache on backend :
backend - system - cache
or try this:
backend - extensions - manage - database - fix
10 years 10 months ago #171989 by jeteran
Illogical, still nothing.
I tried to re-install the languages but neither.
I can't see what else can we try.
10 years 10 months ago #171990 by 810
could you send admin account details to jelle@ kunena.org then i will check it for you.
The following user(s) said Thank You: jeteran
10 years 10 months ago #171991 by jeteran
Wonderful, thanks mate.
10 years 10 months ago #171992 by 810
you had not installed the kunena language pack from the download page.
