Solved Can't get a language installed
10 years 10 months ago #171976 by jeteran
Greetings.
I have a fresh install of Joomla and Kunena, where I update the tables from my previous site.
Kunena runs great, but I am trying now to install Spanish language and it doesn't change.
I tried to find help on the net but the responses are for old posts.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : theme3079 | author: | version: 3.0 | creationdate: April 2014
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.8 | creationdate: 2016-01-12
Kunena version detailed: Kunena 4.0.8 | 2016-01-12 [ Tokyo ]
Plugins: None
Thank you!
10 years 10 months ago #171977 by 810
Replied by 810 on topic Can't get a language installed
Set spanish as default language, backend and frontend. then install the kunena language pack.
Last thing todo is to recreate menu. Backend - kunena - tools - menu manager - recreate menu.
The following user(s) said Thank You: jeteran
10 years 10 months ago #171980 by jeteran
You will called me a complete noob but where do I change the default language?
Thanks mate.
10 years 10 months ago #171982 by 810
backend - extensions - language
10 years 10 months ago #171983 by jeteran
Thank you.
Yes, there are both the site and the administration in Spanish, but still Kunena in English.
I went to Content languages and is only English, it should appear also Spanish since I have installed by the extension manager.
Thanks mate.
10 years 10 months ago #171984 by 810
maybe you set the language for the user that you use. Try to logout on the frontend and check if its correct now.
Else you need to install language by: backend - extensions - manage - install languages
Time to create page: 0.159 seconds
