- Thank you received: 1425
Kunena 7.0.7 Released
Solved Kunena forums incompatible with Joomla's SEO (latest ver. fresh install)
10 years 6 months ago #171688
by 810
Replied by 810 on topic Kunena forums incompatible with Joomla's SEO (latest ver. fresh install)
no it should have no name before so only .httaccess
10 years 6 months ago #171691
by jeteran
Replied by jeteran on topic Kunena forums incompatible with Joomla's SEO (latest ver. fresh install)
That's correct.
I changed but still nothing, is like nothing have been done to the site.
The information inside the .htaccess is:
# @package Joomla
# @copyright Copyright (C) 2005 - 2015 Open Source Matters. All rights reserved.
# @license GNU General Public License version 2 or later; see LICENSE.txt
# READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE!
# The line just below this section: 'Options +FollowSymLinks' may cause problems
# with some server configurations. It is required for use of mod_rewrite, but may already
# be set by your server administrator in a way that disallows changing it in
# your .htaccess file. If using it causes your server to error out, comment it out (add # to
# beginning of line), reload your site in your browser and test your sef url's. If they work,
# it has been set by your server administrator and you do not need it set here.
## No directory listings
IndexIgnore *
## Can be commented out if causes errors, see notes above.
Options +FollowSymlinks
Options -Indexes
## Mod_rewrite in use.
RewriteEngine On
## Begin - Rewrite rules to block out some common exploits.
# If you experience problems on your site block out the operations listed below
# This attempts to block the most common type of exploit `attempts` to Joomla!
# Block out any script trying to base64_encode data within the URL.
RewriteCond %{QUERY_STRING} base64_encode[^(]*\([^)]*\) [OR]
# Block out any script that includes a <script> tag in URL.
RewriteCond %{QUERY_STRING} (<|%3C)([^s]*s)+cript.*(>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL.
RewriteCond %{QUERY_STRING} GLOBALS(
\[|\%[0-9A-Z]{0,2}) [OR]
# Block out any script trying to modify a _REQUEST variable via URL.
RewriteCond %{QUERY_STRING} _REQUEST(
\[|\%[0-9A-Z]{0,2})
# Return 403 Forbidden header and show the content of the root homepage
RewriteRule .* index.php [F]
## End - Rewrite rules to block out some common exploits.
## Begin - Custom redirects
# If you need to redirect some pages, or set a canonical non-www to
# www redirect (or vice versa), place that code here. Ensure those
# redirects use the correct RewriteRule syntax and the [R=301,L] flags.
## End - Custom redirects
# Uncomment following line if your webserver's URL
# is not directly related to physical file paths.
# Update Your Joomla! Directory (just / for root).
# RewriteBase /
## Begin - Joomla! core SEF Section.
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
# If the requested path and file is not /index.php and the request
# has not already been internally rewritten to the index.php script
RewriteCond %{REQUEST_URI} !^/index\.php
# and the requested path and file doesn't directly match a physical file
RewriteCond %{REQUEST_FILENAME} !-f
# and the requested path and file doesn't directly match a physical folder
RewriteCond %{REQUEST_FILENAME} !-d
# internally rewrite the request to the index.php script
RewriteRule .* index.php [L]
## End - Joomla! core SEF Section.
But I think the problem is not around here, what do you think?
Thanks for your time.
# @package Joomla
IndexIgnore *
Options -Indexes
RewriteEngine On
\[|\%[0-9A-Z]{0,2}) [OR]# Block out any script trying to modify a _REQUEST variable via URL.
\[|\%[0-9A-Z]{0,2})# Return 403 Forbidden header and show the content of the root homepage
# RewriteBase /
10 years 6 months ago #171692
by 810
try to read this 3 posts links:
www.kunena.org/forum/k-3-0-general-quest...ess-this-page#150530
10 years 6 months ago - 10 years 6 months ago #171751
by jeteran
Got it!
Was easy. What I did at the beginning was select some tables that I thought were the most important ones from the old site, including categories, topics and users; and copy and replace them in the new site.
What I did was just replace All the tables from one site to another. Everything fix.
Thanks for the follow-up 810. Keep having a great one and happy 2016.
Last edit: 10 years 6 months ago by jeteran.
Time to create page: 0.223 seconds
