Solved Need help with permissions.
11 years 2 months ago #168369 by drake2k
Replied by drake2k on topic Need help with permissions.
rich wrote: Sorry, it was my Browser which has not shown the images.
Can you see them now or do you still need me to upload them?
11 years 2 months ago #168370 by rich
Replied by rich on topic Need help with permissions.
Thank you, I see it now and test with the same setting.
11 years 2 months ago #168373 by rich
I'm sorry, but there are no problems on my test page with this settings. From a distance, the error will be hard to find.
The following user(s) said Thank You: drake2k
11 years 2 months ago #168374 by drake2k
Thank you very much for all your help. May I ask, what steps you took on your test? Maybe there is one I missed some where.
11 years 2 months ago #168375 by rich
I've created 2 access levels such as you, and tested with all settings how to see them on your images.
But in principle, it would be enough, if you would have the user groups only. Try followings: Remove the new access levels and test it only with user groups.
Maybe helps also this video.
11 years 2 months ago - 11 years 2 months ago #168376 by drake2k
Got it.
This video was very good, I wish I had found that earlier.
As it turns out... I was doing it right just fine, It was in the account I was using to test, somehow it's got some extra permissions it's not supposed to have but that's not a Kunena issue.
Your instructions were extremely helpful and I learned a lot. I now have my officer's lounge that only officers can see. Thank you very much!!
Last edit: 11 years 2 months ago by drake2k.
Time to create page: 0.203 seconds
