Solved Need help with permissions.
11 years 2 months ago #168327 by drake2k
I do apologize if this question is beyond simplistic. I've been searching for hours trying to find an answer. Here's what I'm trying to do:
I have three main sections laid on out the forums. The first is a public area using captcha and e-mail to avoid spam. It has 2 child categories.
The second is for registered users only, It has four child categories.
These are working perfectly fine. The third on the other hand is not being nice. This is a section for Higher level users that I called Officers.
I created a Joomla group called Officers, added that group in the 'Special' Viewing Access Level.
In Kunena 4.0.5 I set the Officer parent category to the following:
Access Control Type = User Groups
Primary = Officers
Include child = no
Secondary = Officers
Child = no
I then set the child category in the same exact same fashion except two more options:
Allowed to Post = Officers
Allowed to Reply = Officers
== Please note: I also tried this using Access Level instead of User Groups but that didn't work either.
I'm not exactly sure what I'm doing wrong. The Officer section is being hidden from public wish is correct, but Registered users that are NOT in the officer's group are able to see it, post, AND reply.
I'm missing something and the documentation was a bit outdated and didn't seem to help with this. I did of course find it very informative. So here's a clip of my Report config. If someone could point me in the right direction I would be most grateful.
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.5 | creationdate: 2015-08-17
Kunena version detailed: Kunena 4.0.5 | 2015-08-17 [ Turnau ]
Third-party components: CommunityBuilder 2.0.10 | UddeIM 3.7
Plugins: Content - Kunena Discuss 3.1.0
Modules: Kunena Latest 3.1.1 | Kunena Stats 3.1.0
11 years 2 months ago #168329 by 810
Replied by 810 on topic Need help with permissions.
I think you create the joomla user group level is the same level as registered, so you should check if Officers is under registered, if not then you need to change that.
The following user(s) said Thank You: drake2k
11 years 2 months ago #168346 by drake2k
Replied by drake2k on topic Need help with permissions.
Thank you for your reply. I did create the officer's group as a child of Registered.
Public
- Guest
- Manager
- - Administrator
- Registered
- - Author
- - - Editor
- - - - Publisher
- - Officers
- Site Moderation Group
- Super Users
11 years 2 months ago #168347 by 810
then check the user profile, if they didn't also added on officer level.
11 years 2 months ago #168348 by drake2k
I should have mentioned that, yes, they're in both the registered users and officer's group. Should they only be in officers?
11 years 2 months ago #168349 by 810
normal user should be only "registered "
officer user should be "registered and officer"
Time to create page: 0.153 seconds
