Merged Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first?
13 years 2 months ago #146676 by helene
Yep, thank you.
Will go ahead and try to upgrade then. Not what I do every day, but I am sure it will work out in the end :)
13 years 2 months ago #146677 by helene
I unfortunately get this message ..
JInstaller: :Install: Cannot find XML setup file
Invalid package type. The update can not proceed.
Just asked Joomla support, they asked me to ask you .. do you have any idea what could cause this
13 years 2 months ago #146679 by 810
Did you tried joomla extension updater, or did you tried to install the package.
13 years 2 months ago #146680 by sozzled
Did you read the K 3.0 Upgrade Guide and did you follow the procedure?
13 years 2 months ago - 13 years 2 months ago #146681 by helene
Hi, when I click on the icon saying that kunena needs to upgrade (in Joomla backend controlpanel) it takes me to somewhere saying Kunena live update, I press update to latest version.
I also did read the upgrade guide.
But I asked Joomla support to do it for me after getting this error message, - they obviously got the same message and send it back to me to solve.
I thought they probably would know more about doing it right than I do.
Last edit: 13 years 2 months ago by helene.
13 years 2 months ago #146683 by 810
Hi, yes there is a issue with the updater on J2.5.x, please download the package: www.kunena.org/download and install it using the joomla installer. Then it will be updated.
Regards 810
