- Thank you received: 1
Merged Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first?
13 years 2 months ago - 13 years 2 months ago #146685
by helene
Replied by helene on topic Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first?
Right, - so .. just to be sure.
Cause I also did try this way, - but I am not always doing this quite right, cause I dont quite get this with unzipping
But I upload it not as one package but one at the time right ? component, media, 2 plugins and one called lib_kunena...
This issue .. is that a Joomla issue ? Cause they say if I can directly point to it being an issue with Joomla
they will look into it.
Last edit: 13 years 2 months ago by helene.
13 years 2 months ago #146687
by 810
Replied by 810 on topic Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first?
you don't need to unzip the package.
1) download the package
2) go to joomla installer
3) select package
4) click on install
3) select package
4) click on install
The following user(s) said Thank You: helene
13 years 2 months ago #146689
by helene
Ha .. dont know if you know that feeling, - but my fingers just suddenly hit install and in two seconds it was all done succesfully.... and I was so worried
But all is well ..
Thanks for helping me over my comfort zone
But all is well ..
13 years 2 months ago - 13 years 2 months ago #146690
810 is correct; there is no need to unzip the installation package. Kunena is installed (and upgraded) in the same way as most Joomla packages are installed these days. The main difference is that the package name is called pkg_kunena_<version>_<date>.zip instead of com_kunena_<version>_<date>.zip The package installation method is described (with a video tutorial) in
K 3.0 Installation Guide
I would not recommend the "download-package -> install" method to complete beginners. I recommend the "install by URL" method
I asked before if you read and followed the procedure described in K 3.0 Upgrade Guide . It would seem, from your earlier responses, that you did not do that.
If your site meets the required technical requirements and if you have ensured that other software you may be using that interacts with K 3.0.1 is likewise upgraded, the upgrade procedure takes less than 30 seconds to complete.
Replied by sozzled on topic Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first?
Last edit: 13 years 2 months ago by sozzled.
13 years 2 months ago #146691
by helene
hi sozzled
You know I do read the stuff, but its not always easy to get it right anyway when you are not normally working with these things - and the main thing is really that I am so worried that something unforeseen will occur and make a mess of everything
Fortunately you guys must really know what you are doing, because yeah, it takes no time then its all working well
13 years 2 months ago #146758
by Matias
Replied by Matias on topic Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first?
Unfortunately we have made some changes into our package that makes automatic updates from Kunena 2.0 to fail. I've been investigating the issue and I know what happens but I'm still unsure how to get it fixed.
That said, automated updates should work from Joomla extension manager by clicking on updates (and clearing the cache if the update was not shown).
Just remember to visit Kunena backend after the update to make sure that everything works.
Time to create page: 0.261 seconds
