Merged Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first?
- Oscarfishlover
- Premium Member
13 years 2 months ago #146586
by Oscarfishlover
The #1 Oscar Fish website on the net
Joomla! 2.5.14
Kunena 3.0.2
I've noticed there is an "Update Found Click to Update" tab in the control panel within kunena. Nothing is mentioned about this in the upgrade details on the website. I'm assuming that it's perfectly okay to use this facility. If not, then what's it doing there?
Joomla! 2.5.14
Kunena 3.0.2
13 years 2 months ago - 13 years 2 months ago #146613
by 810
Replied by 810 on topic Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first?
Lasted version is Kunena 3.0.1
Go to extension update, purge cache then check again. Maybe you don't updated a plugin.
Last edit: 13 years 2 months ago by 810.
- Oscarfishlover
- Premium Member
13 years 2 months ago #146642
by Oscarfishlover
Joomla! 2.5.14
Kunena 3.0.2
Replied by Oscarfishlover on topic Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first?
I think I should have made myself a little bit clearer. I'm using version 2.0.4. Can I upgrade straight to 3.0.1, or do I have to start with 3.0?
The reason my IRC original question was as I wanted to know what would happen if I tried to upgrade from the admin section. None of the upgrade instructions on this website mentioned this feature which is confusing.
Joomla! 2.5.14
Kunena 3.0.2
13 years 2 months ago #146643
Replied by sozzled on topic Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first?
You have always been able to go from just about any version of Kunena to the latest version of Kunena without having to go through intermediate minor versions (as long as the version of Joomla you are using supports the version you have and the version you want to go to).
The K 3.0 Upgrade Guide shows you what to do. Is that now clearer for you?
13 years 2 months ago - 13 years 2 months ago #146672
by helene
Replied by helene on topic Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first?
Just realized I should update my Kunena forum, but should I go directly to 3.0.1?
Joomla is vs 2.5.11
Joomla is vs 2.5.11
Last edit: 13 years 2 months ago by sozzled. Reason: Correct typographical error and merge topics
13 years 2 months ago #146673
by 810
The following user(s) said Thank You: helene
Time to create page: 0.273 seconds
