Question After upgrading (3.0.7) the ENTER key does not work.
11 years 6 months ago #162676 by rich
Maybe is the problem to elsewhere. You should check your page.
F-Secure and site advisor shows:
"This website has been reported as harmful. We recommend that you do not visit this website."
The following user(s) said Thank You: Mortti
11 years 6 months ago - 11 years 6 months ago #162681 by Mortti
rich wrote: Maybe is the problem to elsewhere. You should check your page.
This is confirmed also by me, F-Secure and McAfee SiteAdvisor Softwares /also web checkers tell same thing.
Also others... your site is globally in black list as harmful site... check your site and come to ask help about Kunena, when you have solved those things.
Last edit: 11 years 6 months ago by Mortti.
11 years 6 months ago #162866 by Sky_80
unfortunately time ago we had problems with a virus.
solved the problem we have also decided to update Joomla to the latest version. 2.5 to 3.X
unfortunately knew we had to communicate to the various antivirus software house to check the page again because now is good.
The site is secure. ;)
Do you have any advice for my problem with Kunena ??
Thank You.
11 years 6 months ago #162867 by TheresaHJ
I am having the same problem. If anyone does find a solution, please post. In my case, I was able to post fine just a few days ago, and then suddenly "I couldn't." I am wondering if it is related to my Joomla 3.4 upgrade.
11 years 6 months ago #162868 by 810
first try the default joomla template. If you still can't use the enter key, then the problem is on 1 off the plugins. So you must disable all none joomla / kunena plugins, and enable it 1 by 1, until the broken one.
11 years 6 months ago #162869 by Sky_80
TheresaHJ wrote: I am having the same problem. If anyone does find a solution, please post. In my case, I was able to post fine just a few days ago, and then suddenly "I couldn't." I am wondering if it is related to my Joomla 3.4 upgrade.
On my site, the problem was also present on Joomla! 3.3.6
