- Thank you received: 1
configuration report
Question After upgrading (3.0.7) the ENTER key does not work.
11 years 6 months ago #162870
by Sky_80
Replied by Sky_80 on topic After upgrading (3.0.7) the ENTER key does not work.
With the base template works.
I can solve keeping the template momentary ??
11 years 6 months ago #162871
by 810
Replied by 810 on topic After upgrading (3.0.7) the ENTER key does not work.
ok, if the default template works.
Then there is a issue on your js template.
go to templates/your_template/js/
rename the files, check if the enter works, If yes, then rename the file back 1 by one, until the broke one.
Or contact your template builder
11 years 6 months ago #162885
by Sky_80
I try to rename the 3 files inside the folder : template/js ... One at a time.
But unfortunately nothing to do. The problem is not solved.
11 years 6 months ago #162886
by 810
ok, open templates/your_template/index.php
Looks if there is added js from other sites
11 years 6 months ago #162887
by Sky_80
I'm not good with these things ...
this is my index.php file
<?php /** * @copyright Copyright (C) 2014 TheGrue.org - All Rights Reserved. **/ defined( '_JEXEC' ) or die( 'Restricted access' );
$scrolltop = $this->params->get('scrolltop');
$logo = $this->params->get('logo');
$logotype = $this->params->get('logotype');
$sitetitle = $this->params->get('sitetitle');
$sitedesc = $this->params->get('sitedesc');
$menuid = $this->params->get('menuid');
$animation = $this->params->get('animation');
$app = JFactory::getApplication();
$doc = JFactory::getDocument();
$templateparams = $app->getTemplate(true)->params;
$menu = $app->getMenu();
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="<?php echo $this->language; ?>" lang="<?php echo $this->language; ?>" dir="<?php echo $this->direction; ?>">
<head>
<jdoc:include type="head" />
<?php if ( version_compare( JVERSION, '3.0.0', '<' ) == 1) { ?>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.8.3/jquery.min.js"></script>
<?php } else { JHtml::_('bootstrap.framework');JHtml::_('bootstrap.loadCss', false, $this->direction);}?>
<?php include "functions.php"; ?>
<meta name="viewport" content="width=device-width" />
<link rel="stylesheet" href="<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/css/styles.css" type="text/css" />
<link rel="stylesheet" href="<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/css/bootstrap.min.css" type="text/css" />
<link rel="stylesheet" href="<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/css/font-awesome.min.css" type="text/css" />
<!-- Custom CSS For IE -->
<!--[if IE 7]><link rel="stylesheet" href="<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/css/font-awesome-ie7.min.css" type="text/css" /><![endif]-->
<!--[if lt IE 9]><script src="http://html5shim.googlecode.com/svn/trunk/html5.js"></script><script src="http://css3-mediaqueries-js.googlecode.com/svn/trunk/css3-mediaqueries.js"></script><![endif]-->
<!-- Custom CSS -->
<link href='http://fonts.googleapis.com/css?family=Coda' rel='stylesheet' type='text/css'>
<?php if ($scrolltop == 'yes' ) : ?>
<script type="text/javascript" src="<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/js/scroll.js"></script>
<?php endif; ?>
</head>
<body class="background">
<div id="header-wrap" class="container row clr">
<div id="header" class="clr">
<div id="header-i" class="clr">
<div id="logo" class="col span_4">
<?php if ($logotype == 'image' ) : ?>
<?php if ($logo != null ) : ?>
<a href="<?php echo $this->baseurl ?>"><img src="<?php echo $this->baseurl ?>/<?php echo htmlspecialchars($logo); ?>" alt="<?php echo htmlspecialchars($templateparams->get('sitetitle'));?>" /></a>
<?php else : ?>
<a href="<?php echo $this->baseurl ?>/"><img src="<?php echo $this->baseurl; ?>/templates/<?php echo $this->template; ?>/images/logo.png" border="0"></a>
<?php endif; ?><?php endif; ?>
<?php if ($logotype == 'text' ) : ?>
<a href="<?php echo $this->baseurl ?>"><?php echo htmlspecialchars($sitetitle);?></a>
<?php endif; ?>
<?php if ($sitedesc !== '' ) : ?>
<div id="site-description"><?php echo htmlspecialchars($sitedesc);?></div>
<?php endif; ?>
</div><!-- /logo -->
<?php if ($this->countModules('top')) : ?>
<div id="top" class="col span_8"><div id="top-i" class="clr">
<jdoc:include type="modules" name="top" style="none" />
</div></div>
<?php endif; ?>
<?php include "social.php"; ?>
</div>
</div>
</div>
<?php if ($this->countModules('menu')) : ?>
<div id="navbar-wrap">
<nav id="navbar" class="container row clr">
<div id="navigation" class="span_12 col clr">
<jdoc:include type="modules" name="menu" style="menu" />
</div>
</nav>
</div>
<div class="clr"></div>
<?php endif; ?>
<?php if (is_array($menuid) && !is_null($menu->getActive()) && in_array($menu->getActive()->id, $menuid, false)) { ?>
<div id="slide-wrap" class="container row clr">
<?php include "slideshow.php"; ?>
</div>
<?php } ?>
<div id="wrapper-w" class="container row clr">
<?php $menu = $app->getMenu(); if ($menu->getActive() == $menu->getDefault()) { ?>
<div class="blue-point"><?php jlink(); ?></div>
<?php } ?>
<div id="wrapper"><div id="wrapper-i">
<?php if ($this->countModules('user1')) : ?>
<div id="user1-wrap" class="container row clr"><div id="user1" class="clr">
<jdoc:include type="modules" name="user1" style="usergrid" grid="<?php echo $user1_width; ?>" />
</div></div>
<?php endif; ?>
<?php if ($this->countModules('breadcrumbs')) : ?>
<jdoc:include type="modules" name="breadcrumbs" style="none"/>
<?php endif; ?>
<div id="box-wrap" class="container row clr">
<div id="main-content" class="row span_12">
<?php if ($this->countModules('left')) : ?>
<div id="leftbar-w" class="col span_3 clr">
<div id="sidebar">
<jdoc:include type="modules" name="left" style="grid" />
</div>
</div>
<?php endif; ?>
<div id="post" class="col span_<?php echo $compwidth ?> clr">
<div id="comp-wrap">
<jdoc:include type="message" />
<jdoc:include type="component" />
</div>
</div>
<?php if ($this->countModules('right')) : ?>
<div id="rightbar-w" class="col span_3 clr">
<div id="sidebar">
<jdoc:include type="modules" name="right" style="grid" />
</div>
</div>
<?php endif; ?>
</div>
</div></div>
</div>
<?php if ($this->countModules('user2')) : ?>
<div id="user2-wrap" class="container row clr"><div id="user2" class="clr">
<jdoc:include type="modules" name="user2" style="usergrid" grid="<?php echo $user2_width; ?>" />
</div></div>
<?php endif; ?>
<div id="footer-w"><div id="footer" class="container row clr" >
<?php if ($this->countModules('copyright')) : ?>
<div class="copyright">
<jdoc:include type="modules" name="copyright"/>
</div>
<?php endif; ?>
<?php if ($this->countModules('footer-menu')) : ?>
<div id="footer-nav">
<jdoc:include type="modules" name="footer-menu" style="none" />
</div>
<?php endif; ?>
</div></div>
</div>
</body>
</html>
11 years 6 months ago #162949
by Sky_80
help me...
Time to create page: 0.225 seconds
