Question After upgrading (3.0.7) the ENTER key does not work.
11 years 6 months ago #162647 by Sky_80
I upgraded recently Kunena 3.0.7
After upgrading the ENTER key does not work.
If I open / edit a topic, and I press the ENTER key, does not work.
how do I fix ??
Thank You
Ps - sorry my English. : p
11 years 6 months ago #162648 by Sky_80
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 25M
Joomla default template details : Blue-Point | author: TheGrue.org | version: 3.3 | creationdate: Unknown
Kunena default template details : Euro Colors | author: Kevin Mamaqi | version: 1.2.0 | creationdate: 2013-12-25
Kunena version detailed: Kunena 3.0.7 | 2015-02-01 [ Galah ]
Plugins: Content - Kunena Discuss 3.0.7
Modules: Kunena Latest 3.0.1
11 years 6 months ago #162651 by 810
So for new line?
try default kunena template.
11 years 6 months ago #162658 by Sky_80
Yes... For a new line.
The problem also exists with the original template.
I try to change template thinking to solve, but nothing.
11 years 6 months ago #162659 by 810
try switching joomla template.
11 years 6 months ago - 11 years 6 months ago #162672 by sozzled
Sky_80 wrote: I upgraded recently Kunena 3.0.7
I am interested to know more about the cause of this problem, whether the problem was caused by updating to K 3.0.7 or by something else.
One thing is certain: this problem does not happen here, at this website (which uses J! 2.5 and K 3.0.7). I have not seen any other reports by other members of this community where the problem happens with K 3.0.7 and J! 3.x, either.
I suspect that the reason the ENTER key does not generate a new line on your website is some Javascript routine that's intercepting your keystrokes and processing the ENTER key differently. As far as I know there was no change made to the K 3.0.7 Javascript library; there have been no announcements from the developers aout changes to the K 3.0.7 Javascript library.
It is possible that you have a Javascript library added by another Joomla extension that you are using. Unless I knew more about your website, I cannot help you better. As you know, only the forum moderators here can see the extra, confidential information contained in your Kunena configuration report; I am not a moderator here and I do not have that kind of access to be able to help you.
Last edit: 11 years 6 months ago by sozzled.
Time to create page: 0.266 seconds
