Question SSL certificate problem
11 years 9 months ago - 11 years 9 months ago #162132 by sozzled
xillibit wrote: .... it's not an issue in Kunena
Technically-speaking, the "issue" was created by an untested, unannounced change by the Kunena developers when they moved hosting of the installation packages at Sourceforge to GitHub.
xillibit wrote: It's a server issue with some servers. Those same servers in theory would have issues pulling the Joomla core updates (3.3.6 is using GitHub) ...
In effect, this says it's an end-user problem. Technically-speaking, this may be correct; however, it is not helpful to lay the blame on the end users for mistakingly trusting the auto-upgrade process when the problem was caused by an untested, unannounced change created by the Kunena developers in the first place.
What is needed here is less finger pointing and more empathy for the end users and, I'm sorry to say, there seems to be a lot more of the former attitude that seems to be on display here in recent times.
Last edit: 11 years 9 months ago by sozzled.
The following user(s) said Thank You: xristo
11 years 9 months ago #162134 by xillibit
Replied by xillibit on topic SSL certificate problem
Some people has no issues to upgrade to Kunena 3.0.7 others encounter the issue described above.
Just look around on the web, you will see plenty of issues with SSL and curl:
11 years 9 months ago - 11 years 9 months ago #162139 by sozzled
xillibit wrote: Some people has no issues to upgrade to Kunena 3.0.7 others encounter the issue described above.
I searched this forum for "SSL certificate problem" and I can find no reference to this problem — in connection with the Joomla "auto-upgrade" procedure for Kunena — until the release of K 3.0.7.
Since this was written (in msg #6 of this topic) the message has been changed. Is this a Kunena issue or is it not?
I have some questions:
1) If people are currently using K 3.0.6 on their websites and they see the message on their Joomla dashboard: what should they do?
2) What if people see the message on their Joomla dashboard that there is an update available for Kunena?
3) If there is a "SSL certificate problem", where does this problem come from?
4) Did the problem originate because of something that has changed between K 3.0.7 and K 3.0.6?
5) If the answer to question 4 is yes, what has changed and who was responsible for the change?
6) If the answer to question 5 is that the Kunena developers were responsible for making a change, what are the Kunena developers doing about resolving the issue so that it does not occur in future?
7) In msg #5 above, I asked if the moderators have any intention of merging together the five other topics on this "auto-upgrade" issue" so that they will assist the community better by collecting the information in one place?
8) When the developers say that "some people" may have this problem, do you know how many people may have this problem; is it a small number or is it a significant number of people?
11 years 9 months ago - 11 years 9 months ago #162143 by Mortti
Replied by Mortti on topic SSL certificate problem
I think that the problem is all the add-on developers, who transferred or keep their packages for download on GitHub... same problem is also a self Joomla! Project, as they consider the place where the packages are loaded(eg. language packs, extensions etc.)... It all started here in my opinion --> developer.joomla.org/news/602-joomlacode-is-closing.html
EDIT: I think Kunena Developers find solution soon...
Last edit: 11 years 9 months ago by Mortti.
11 years 9 months ago - 11 years 9 months ago #162144 by sozzled
Mortti wrote: It all started here in my opinion --> developer.joomla.org/news/602-joomlacode-is-closing.html
Thanks, Mortti. I read that article a couple of weeks ago. I understand that there are good reasons for Joomla to close Sourceforge.
However, this does not answer the questions I asked in msg #9 above.
The fact is that "some users"—we do not know if it is a small number or a significant number of people—are having problems with the Joomla "auto-upgrade" procedure for K 3.0.7.
There may be other problems involving the newest release of Kunena that are associated with the GitHub issue .
It is also a fact that there are a growing number of topics relating to this "SSL certificate problem"—that only happens when people use the Joomla "auto-update" process— and the forum moderators seem to be treating them separately. Instead of tackling them separately, I think it would be a good idea if the topics were merged together into one topic so that all of these matters can be discussed in one place. I still have not heard from the developers if they are prepared to manage this problem as one topic so that all of these questions can be handled in one place or deal with each new topic separately as they arise.
11 years 9 months ago #162146 by 810
Hi Michael,
We are not merging topics together, The mean reason. Is that users don't find the fix quickly.
With multiple topics users can quickly see the same issue, and isn't opening a new question.
Ontopic, we are moving from github to an other file hoster. We need to find a good service provider.
