configuration report
Solved
Problems setting up Kunena forum on my website
I'm more perplexed.. trying to understand.. Does Kunena sit in a module on my page where I can change my background color or is this performed with CSS code in via my template.
I was hoping to utilize ads on the sides as well. But, maybe this is another question in another section..
