- Thank you received: 2
Solved Problems setting up Kunena forum on my website
Also I don't want it on my home page. I have another page that I'm setting up for it.
Please advise.. this should not be this difficult. I don't see it anywhere, .. I use Joomla 3.3. Thanks
agabby
Agabby
This picture shows the top of Kunena and the bottom of my menu.. there are no tabs at the top. Please advise.
Thank you..
(i write this because other people can see the issue.)
Also I cannot figure out it sits on my page but I cannot design the background under Template Manager.
I know the template is able to receive Kunena because the template developer uses it as well.
