Merged K 3.0: cannot upload attachments - ADD FILE button does not work
See K 3.0 Upgrade Guide to learn more about how to downgrade to K 2.0.
- HardstylerDK
- Senior Member
To detect which script is causing a conflict you need to disable all your plugins and modules, and re-enable them one by one by checking each time it it's work, like that you will find the culprit
Which browser are-you using ?
- HardstylerDK
- Senior Member
The funny things is that it works if i click on the button at the top of it - but then if i want to delete the image i inserted it just opens the file manager window again, and also if i try to insert it.
Then how could you say that "nothing" has changed if you were running K 2.0 before (which does not work on J! 3.1.1) when things supposedly worked and now?HardstylerDK wrote: The problem first began after updating from Kunena 2.x to Kunena 3.x.
You see, there's another element in this situation that has little to do with Kunena.
When you were running K 2.0 (presumably on a different version of Joomla) when things worked, you had a certain mix of software components, modules, plugins, etc., that you were using. When you migrated your site to J! 3.1.1 you probably had to revisit those other Joomla extensions and needed to upgrade, modify, remove or add something else for your site to work in J! 3.1.1. And that's the key difference!
Something else, that you added or changed in the software "soup" added a Javascript library that intereferes with Joomla's Mootools Javascript library and thereby prevents Kunena from functioning. Therefore, it's difficult to accept that you can be as confident that nothing has changed between when things were working and now, when things are not working. There's a whole change of Joomla platform involved and, in that process, something has changed.
inserting attachment in my Kunena 3.0.2 not working. Nothing happens if I click on the "Add file" button or Attachments text area.
You have any explanation?
