Merged K 3.0: cannot upload attachments - ADD FILE button does not work
13 years 3 months ago #146768 by HardstylerDK
I've got some problems trying to attach pictures to a topic, the buttons doesn't respond at all.
I've read that it could be a javascript or mootools problem, but can't figure it out - haven't got any module that loads it.
Here is my Report Configuration:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 200M
Joomla default template details : leo_tech | author: LeoTheme.com | version: 3.0.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.1 | creationdate: 2013-06-29
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Third-party components: UddeIM 3.0
Plugins: None
Hope that one of you guys can help me out. :)
13 years 3 months ago #146777 by HardstylerDK
13 years 3 months ago #146782 by sozzled
HardstylerDK wrote: I've read that it could be a javascript or mootools problem, but can't figure it out - haven't got any module that loads it.
This is taken from your website:
<script src="/media/jui/js/jquery.min.js" type="text/javascript"></script> <script src="/media/jui/js/jquery-noconflict.js" type="text/javascript"></script> <script src="/media/plg_system_sl_scrolltotop/js/scrolltotop_jq.js" type="text/javascript"></script> <script src="/media/system/js/mootools-core.js" type="text/javascript"></script> <script src="/media/system/js/core.js" type="text/javascript"></script> <script src="/media/system/js/mootools-more.js" type="text/javascript"></script> <script src="/media/kunena/js/mediaboxAdv.js" type="text/javascript"></script> <script src="/media/kunena/js/default.js" type="text/javascript"></script> <script src="/plugins/system/jcemediabox/js/jcemediabox.js?version=1110" type="text/javascript"></script> <script src="/media/system/js/modal.js" type="text/javascript"></script> <script src="http://www.elektroniktest.dk/templates/leo_tech/js/global.js" type="text/javascript"></script> <script src="http://www.elektroniktest.dk/plugins/system/leofw/bootstrap/js/bootstrap.js" type="text/javascript"></script> <script src="http://www.elektroniktest.dk/plugins/system/leofw/js/custom.js" type="text/javascript"></script> <script src="/media/com_acymailing/js/acymailing_module.js" type="text/javascript"></script> <script src="http://ajax.googleapis.com/ajax/libs/swfobject/2.2/swfobject.js" type="text/javascript"></script> <script src="/modules/mod_universal_ajaxlivesearch/engine/dojo.js" type="text/javascript"></script> <script src="https://ajax.googleapis.com/ajax/libs/dojo/1.6/dojo/dojo.xd.js" type="text/javascript"></script> <script src="/modules/mod_universal_ajaxlivesearch/cache/153/8aac5f839f28bca87dc3de2ab2469d85.js" type="text/javascript"></script> <script src="/modules/mod_jse_megamenu/assets/js/HoverIntent.js" type="text/javascript"></script> <script src="/modules/mod_jse_megamenu/assets/js/script.js" type="text/javascript"></script> <script src="/modules/mod_janewsticker/assets/script.js" type="text/javascript"></script>
You cannot run a Joomla website without Javascript and you cannot run Kunena without the Joomla Mootools Javascript library.
Compare the list of files loaded on your Joomla 3.1.1 site with the following list (taken from a "vanilla-flavoured, no-frills, nothing-else-added site" were everything works):
<script src="/media/system/js/mootools-core.js" type="text/javascript"></script> <script src="/media/system/js/core.js" type="text/javascript"></script> <script src="/media/system/js/mootools-more.js" type="text/javascript"></script> <script src="/media/kunena/js/mediaboxAdv.js" type="text/javascript"></script> <script src="/media/kunena/js/default.js" type="text/javascript"></script> <script src="/media/jui/js/jquery.min.js" type="text/javascript"></script> <script src="/media/jui/js/jquery-noconflict.js" type="text/javascript"></script> <script src="/media/jui/js/bootstrap.min.js" type="text/javascript"></script>
Somewhere in the difference between your site (where 20 files are loaded) and the example site (where 8 Javascript files are loaded) lies the answer. If I had to guess, I would say the problem stems from either (or both) the "jse_megamenu", the "janewsticker" modules but, really, it could be anything. The general principle - to understand the issues involved - lies in Javascript and Kunena .
13 years 3 months ago #146787 by HardstylerDK
Just tried to unpublish both the janewsticker and the jsemegamenu, without any difference - still stuck.
The problem first began after updating from Kunena 2.x to Kunena 3.x.
13 years 3 months ago - 13 years 3 months ago #146790 by sozzled
HardstylerDK wrote: Just tried to unpublish both the janewsticker and the jsemegamenu, without any difference - still stuck.
I was guessing. As I wrote, the cause could be anything that prevents the Javascript-activated file-select dialog running which, in turn, stops you selecting a file to upload and save as an attachment.
HardstylerDK wrote: The problem began ...
There should be no difference between the Javascript using in K 2.0 and K 3.0. Are you 100% sure that you have not added anything else to your site, between when you were using K 2.0 (when things worked) and now? :dry:
Last edit: 13 years 3 months ago by sozzled.
13 years 3 months ago #146801 by HardstylerDK
I know buddy. :)
Yeah, 100% sure.
Time to create page: 0.170 seconds
