Sticky Users are unable to change or upload avatar images (Gravatar plugin is enabled)
12 years 8 months ago #147314 by sozzled
*** Topics merged ***
smOOthMKD: please see msg #4 of this topic for the answer.
12 years 8 months ago #147665 by gonza28
Replied by gonza28 on topic Problem change avatar
Hi guys. sorry, my English is not good.
I need help on my forum avatar.
  I can not change avatar.
loa are upgraded to latest version and still the same. may be my mistake.
I have enabled integration plugin avatar. I have enabled all pictures uploaded to the forum but I see no option to change avatar.
Thank you for your help. a hug
12 years 8 months ago #147680 by Jiminimonka
Replied by Jiminimonka on topic Problem change avatar
Post your configuration report please.
Please read the FAQ.
Only one question per topic.
The following user(s) said Thank You: gonza28
12 years 8 months ago #147685 by sozzled
Replied by sozzled on topic Problem change avatar
G'day, gonza28, and welcome to Kunena.
I am guessing that you have enabled the Kunena - Gravatar plugin. If you have enabled this plugin, you and your users will use Gravatar avatar images and you cannot change those images in Kunena. You can only change those images if you login to the Gravatar site and change them there. But that's just a wild guess.
Jiminimonka is right. We may be able to answer your question better (and quicker) if we see your configuration report .
12 years 8 months ago - 12 years 8 months ago #147715 by gonza28
Thank you for your responses. I have generated the report and this is the code.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 8M
Joomla default template details : joomla1 | author: | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Plugins: None
Modules: Kunena Login 3.0.1
neither has happened that I can not access the front end of the site. I'm a programmer in java (android newbie), but little or nothing joomla. yesterday not play anything and suddenly I can not access the site. I left consultations joomla forums but no answers.
Last edit: 12 years 8 months ago by gonza28.
12 years 7 months ago #148674 by dfgrbac
Just a quick note since I had this same problem. This might help some others.
I am using Kunena with JomSocial. After trying to get the Kunena avatar to work for several hours, I noticed that the Kunena - JomSocial Integration plugin was not enabled. This fixed the problem for me.
I was under the impression that setting the configuration in both was enough. I didn't realize that plugin needed enabled separately.
Time to create page: 0.281 seconds
