Sticky Users are unable to change or upload avatar images (Gravatar plugin is enabled)
13 years 3 weeks ago #149081 by rickk
Replied by rickk on topic Avatar Gravatar
Hi Folks,
Finally got Kuenea installed (2.5 no category option for 2.5 so perhaps I am in the wrong place))and I am looking to allow association of an avatar with a registered user. I have upload set to yes and allow visibility to yes. I would assume that somewhere in the profile edit mode a user would be allowed to upload an image. Clearly my assumption is wrong and I am missing something somewhere. Could someone point me in the right direction?
Rick
Configuration report :
htaccess: Exists | PHP environment: Max execution time: 660 seconds | Max execution memory: 512M | Max file upload: 360M
Joomla default template details : js_wright | author: Joomlashack | version: 3.1.2 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Plugins: None
13 years 3 weeks ago - 13 years 3 weeks ago #149084 by sozzled
Replied by sozzled on topic Avatar Gravatar
*** Topics merged ***
rickk wrote: Finally got Kuenea installed (2.5 no category option for 2.5 so perhaps I am in the wrong place) ...
The categories in this forum are based around versions of Kunena - as opposed to versions of Joomla - and, because K 3.0 operates on J 2.5 as well as J! 3.1, you have posted your question in the right place (except that I have merged your question here because it is similar to other questions we have received on this subject).
rickk wrote: ... I am looking to allow association of an avatar with a registered user. I have upload set to yes ... [but] clearly ... I am missing something somewhere. Could someone point me in the right direction?
The answer is actually contained in the subject that you chose for your topic. If you choose to use Gravatar avatar images then you impose, on your users, the restriction that the only way they can change their avatar image on your forum is to go to the Gravatar site and update their avatar image there. If you want your users to use images that are not Gravatar images, disable the Kunena - Gravatar plugin.
It's a one-thing-or-another choice; you can't have both.
Last edit: 13 years 3 weeks ago by sozzled.
13 years 3 weeks ago #149102 by rickk
Thanks Sozzled... I too had enabled the gravatar plugin. :blush:
13 years 3 weeks ago #149104 by rickk
yep, you nailed it. The subject was an expression of my confusion. I didn't know the difference between Avatar & Gravatar and the search terms I used to find an answer were obviously wrong as well. In any event your explanation was clear and helpful.
Thanks!
12 years 11 months ago - 12 years 11 months ago #150845 by koryo
Kunena Dear moderators, I have problems: kunena profile and also in avatar.
I uploaded community builder and if there avatar but registration activation fails.
So I've decided to eliminate community builder and leave again if kunena avatar.
I hit the problems I listed in report configuration if I could support this problem ..
I have dizzy for two weeks.
Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 64M | Max file upload: 25M
Joomla default template details : traction | author: Shape5.com | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party SEF components: sh404sef 4.2.1.1586
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
Last edit: 12 years 11 months ago by sozzled. Reason: Translate topic to English; reveal config report; move topic to General questions category
12 years 11 months ago #150854 by Mortti
At first you shuold look your | Kunena integration settings: You are setted that AUP, CB and Kunena Avatars is use... select one... disable AUP and CB avatars if you want use Kunena avatars in Kunena?
Time to create page: 0.175 seconds
