Sticky Users are unable to change or upload avatar images (Gravatar plugin is enabled)
12 years 9 months ago #150857 by sozzled
*** Topics merged ***
12 years 5 months ago - 12 years 5 months ago #155340 by on4bam
After using Kunena for a long time in Joomla 1.7 to 2.5 without any trouble. Preparing for the migration for Joomla 3.x I installed the 2.5 production site on my local PC via kickstart/akeeba backup thus having a perfect working copy of the site including all extensions.
After upgrading Joomla to 3.2.3 I saw no problems with Kunena 3.0.5. Now that the updated site is transferred back to the server I notice that Avatars are no longer shown in the forum and when editing the profile I no longer see the option "Avatar Image"
User Account Profile Information [strike]Avatar Image[/strike] Forum Settings
As far as I can see (comparing with the old settings) all settings are correct, but there is obviously a problem somewhere.
Any thoughts?
Thanks.
Maurice
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : ON6WL_2014 | author: Ken Andries | version: 1.0 | creationdate: Unknown
Third-party components: UddeIM 3.3
Plugins: None
Modules: Kunena Latest 3.0.1
Last edit: 12 years 5 months ago by sozzled. Reason: Remove spoiler tags surrounding config. report
12 years 5 months ago #155341 by on4bam
I finally found the problem. After disabling the plugin Kunena - Gravatar Integration the avatars are back..
Also "Show Avatar on Categoriy(*) Index and Recent Topics" is now set to NO
(*) the typo is not mine ;) it's like this in configuration>>Frontend
So, problem solved.
11 years 11 months ago #159627 by Marker
On my site when I go to edit my options, all I have are the text options, I don't have the ability to change my avatar. Screenshot via gyazo
11 years 10 months ago #159954 by Wilson
Check if the avatar is right here in the directory /media/kunena/avatars/... ?
Time to create page: 0.217 seconds
