Question SEF issues with Kunena 3 on Joomla 2.5
13 years 3 months ago #145109 by Andyman
As a test, I created another menu containing only an alias pointing to the Kunena Menu:
www.culdceptcentral.com/index.php/culdce...ldcept-satps1-guides (top of the left column)
Unfortunately, it's pointing to the exact same wrong address as the Forum link in the top menu and likewise gives a 404. Is there another way I can link to the forum without disabling SEF?
13 years 3 months ago #145110 by Andyman
OK, I conducted another test. I created a module for the Kunena Menu and put it on a page to test:
www.culdceptcentral.com/index.php/culdce...pt-satps1-card-lists
Note how all of the Kunena Menu links have Contacts in them and result in 404. This is after deleting the Kunena Menu completely and recreating it via the Tools menu.
I have no idea what is causing this, though I'm sure it has something to do with SEF not working correctly.
13 years 3 months ago #145162 by Andyman
I just solved it. Apparently there's an issue in Joomla 2.5 that messes up newly-created menu items when SEF is enabled on some sites, but if you Rebuild the menu item after creating it, the problem goes away.
forum.joomla.org/viewtopic.php?f=624&t=6...bf&start=30#p3041638
Thanks! I really appreciate your replies and willingness to help!
