Merged K 3.0: "There are no published categories in ." message
12 years 10 months ago #151239 by ralf
Hi guys,
I read that thread but it's closed: www.kunena.org/forum/K-2-0-General-Quest...are-missing?start=80
I got exactly the same case - I have setup a website for a client a while ago, in the meantime version 3.0 rolled out and we updated. He started using his website and now not only categories are not displaying but also you can't post anything (because it seems like none of the categories are active).
Any ideas?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : corporative | author: BDThemes | version: 1.2.0 | creationdate: Unknown
Kunena default template details : Corporative 1.0 | author: BDThemes | version: 1.0.0 | creationdate: 2012-12-24
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Plugins: None
12 years 10 months ago - 12 years 10 months ago #151256 by sozzled
G'day, ralf, and welcome to Kunena.
The important information, that was missing until I visited your website, is the information displayed in your site's forum Index page.
This means that there are no published sections or categories defined in the Kunena Category Manager. I suggest you look again at the sections and categories that are defined for your forum.
As a matter of curiosity, did this problem start after migrating your site from J! 1.5?
Last edit: 12 years 10 months ago by sozzled.
12 years 10 months ago #151259 by ralf
Hi Sozzled,
Thanks for taking your time. There are categories posted as you'll see in search dropdown.
I've been to the article you posted and the issue I found is I don't have "sections" in Kunena 3.0.2. There are only categories.
The problem started from migrating from Kunena 2 to 3. I have local copy with Kunena 2 and it works fine (on the same website) but it seems like version 3 was very much rebuilt. I don't see any changes in DB tho (on both local and live websites).
The suggestion I guess would be to remove Kunena from live and move older version from localhost but that's not the solution
Thanks,
Ralf
12 years 10 months ago #151265 by sozzled
ralf wrote: I've been to the article you posted and the issue I found is I don't have "sections" in Kunena ...
Kunena will not work if your categories are not contained within sections.
12 years 10 months ago #151267 by ralf
Well that's the thing! :S
I don't have sections in Kunena v.3
I checked every single setting! I guess I can blame update process fail?
This is what I see under forum categories (no sections like per documentations).
12 years 10 months ago #151268 by sozzled
