Solved Tabs in administration bar does not work
12 years 7 months ago #149957 by rich
I think, it's a Script problem. Can you please to check with Firebug, which scripts to run?
12 years 7 months ago - 12 years 7 months ago #149958 by rich
I have asked now. Go to Extensions > Plugin Manager. Set kunena plugin to first to the ordering. So load kunena system plugin first.
Last edit: 12 years 7 months ago by rich.
12 years 7 months ago #149962 by FFalchrom
I tried...and still problem is the same =(
12 years 7 months ago - 12 years 7 months ago #149970 by rich
I see the number zero for this plugin.
Try the following:
1. Choose all system plugins (not only Kunena plugins)
2. Insert the number one in the field and then save.
12 years 7 months ago #149977 by FFalchrom
WOW O_O It helped...I changed it to Nr 1 and also i switched off SocComment plugin...and now it works. Thank you!!
12 years 7 months ago #149979 by rich
You are welcome! :)
Time to create page: 0.239 seconds
