Solved Tabs in administration bar does not work
12 years 7 months ago #149945 by FFalchrom
Hello everyone!
I’ve got problem with my Kunena 3.02 (heh, I cannot update it via joomla, it simply cannot find updates =(( ), but my problem is connected to administration. I tried to take out moderation from one of the users, but I cannot get to this tab…I click on it, in url bar appears additional prefix, but page does not change… What is the reason of this problem and how can I solve it?
12 years 7 months ago #149946 by sozzled
G'day, FFalchrom, and welcome to Kunena.
We do not know what is the problem in your case. Without seeing your configuration report it is next-to-impossible to guess which one of the hundreds of possible reasons may be causing the problems you are having with your Joomla administration site. Perhaps your Joomla website is broken? Perhaps your installation of Kunena was incomplete or broken in the first place?
K 3.0.2 has been superseded by K 3.0.3. I suggest that you upgrade to K 3.0.3 using the method described in K 3.0 Upgrade Guide
We have discussed before about "tabs in the adminstration" not working and, nine times out of ten, these problems were caused by a bad installation of Kunena or by not using the recommended guide I just mentioned.
12 years 7 months ago #149947 by FFalchrom
The problem is, that before it worked OK until I've installed 3.02 =(
12 years 7 months ago - 12 years 7 months ago #149948 by sozzled
The problem is that we know nothing about your site. In addition to what I wrote before, the other advice I can offer you is to see our FAQs page.
Last edit: 12 years 7 months ago by sozzled.
12 years 7 months ago #149949 by FFalchrom
I would like to get real help =) Which data do you need?
12 years 7 months ago #149950 by FFalchrom
htaccess: Exists | PHP environment: Max execution time: 180 seconds | Max execution memory: 256M | Max file upload: 32M
Joomla default template details : iFreedom-FJT | author: FJT | version: 2.5.0 | creationdate: Unknown
Kunena default template details : Fast Reply at page bottom 2.0 | author: denkubani.ru | version: 2.0.2 | creationdate: 2012-09-02
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Plugins: None
Time to create page: 0.245 seconds
