Question how to attach an mp3 in a post
13 years 2 months ago #146991 by DarKMaSk
coder4life wrote: Out of curiosity, is this the only text you are submitting to the form. Is there no alternate text being inserted outside the brackets? We have an issue with submitting things in a TAG based scenario {tag}{/tag}. The reason it has not been fixed is because it requires a bit of work.
The problem is solved but I think if there be a soundcoloud widget button in the bbcode, that would be much helpful, because it is very difficult for a normal user to place a code inside a post. And moreover to let them know we have to make a big tutorial with screenshots. :(
Please think over it.
The topic has been locked.
13 years 2 months ago #146992 by DarKMaSk
@coder4life - I have found this to happen sometimes. You can't have just the tags and no text, there has to be something else in the post or it won't allow you to save it.
@DarKMaSk - Make sure you have some text in the post you make and see if it works then.
Thank you Jiminimonka, thanks a lot. It worked and the widget is running with its full glory. All the feature of the widget are present and working flawlessly. But, one small thing is there. Is there any way to reduce the height of the widget ?
I love Kunena, Kenena forum and I love you guys and gals. I love you all. I never experienced such a help, such a response on a free product. The 'FREE PRODUCT' can beat commercial products in every aspect, Kunena is the best example on that.
My regards to all of you.
The following user(s) said Thank You: Jiminimonka
13 years 2 months ago #147014 by Jiminimonka
Glad to help.
The widget height is controlled in AllVideos, you will have to play around with the settings in the admin panel for that, not sure if it will work but let us know.
While a BBCode button would be nice, its not too complicated to just put a post on your forums showing the users how you did it.
Please read the FAQ.
Only one question per topic.
The following user(s) said Thank You: DarKMaSk
13 years 2 months ago #147028 by DarKMaSk
Friends, I don't know whether I should post this because it may seems as an announcement but it is not. I humbly want to share some info regarding which I tried to solve but couldn't. Now it has been solved with the help of the friends in support and in the administration here. The entire credit goes to them, specially to the moderator Jiminimonka regarding this one.
Here is the link where you find the solution:
how to embed soundcloud widget inside a Kunena post
I hope it will be helpful.
The following user(s) said Thank You: Jiminimonka, welluforcedme
Time to create page: 0.294 seconds
