Question how to attach an mp3 in a post
12 years 10 months ago - 12 years 10 months ago #146950 by DarKMaSk
Can anyone help about attaching an mp3 in a post from frontend and would be played on click ? The users are able to access the front-end only. Btw, allvideos plugin is not working.
Configuaration:
Joomla: 3.1.4
PHP: 5.3.24
mysql: 5.1.61
kunena: 3.0.1
Last edit: 12 years 10 months ago by DarKMaSk.
The topic has been locked.
12 years 10 months ago - 12 years 4 months ago #146951 by Jiminimonka
AllVideos should work if you follow these instruction.
1. Make sure you have the latest version installed.
[strike]2. Go to Kunena Configuration > BBCode and set Auto-Link URLs to No.[/strike]
3. Go to Joomla Plug-in Manager > System - Kunena Forum setting so that Joomla Content Plugin Support is set to Yes.
EDIT: You no longer need to turn off Auto-Link URLs in the latest version of Kunena
AllVideo can then be used, but you will most likely have to use the short version, ie no URL, so for youtube you would just put the number after the = sign e.g. {youtube}123456{/youtube}.
Example:
{soundcloud}http://soundcloud.com/zone0/sayonara-days-gone-bump{/soundcloud}
For future reference, the information in your signature is not your configuration report and would not help debugging most issues that arise.
Please read the FAQ.
Only one question per topic.
Last edit: 12 years 4 months ago by Jiminimonka. Reason: No longer need to turn of URL Auto-Link
The following user(s) said Thank You: DarKMaSk
12 years 10 months ago - 12 years 10 months ago #146964 by DarKMaSk
Jiminimonka wrote: AllVideos should work if you follow these instruction.
Example:
Thank you for a quick reply. I did the exact things as you told but when I hit the submit button this error showed up:
"Error:Cannot save message: Message body is empty!"
And btw, I have no signature. I Just put a dotted line before starting the configuration list. I think the dotted line made the confusion. Next time I will not use that.
12 years 10 months ago #146967 by sozzled
DarKMaSk wrote: I ... put a dotted line before starting the configuration list. I think the dotted line made the confusion. Next time I will not use that.
What you showed in msg #1 is not what we describe as a configuration report. Information that will help you to produce a more useful Kunena configuration report is given at the top of this page, in the FAQs page and in K 3.0 Configuration Report . I hope that helps you in future.
12 years 10 months ago #146977 by coder4life
Out of curiosity, is this the only text you are submitting to the form. Is there no alternate text being inserted outside the brackets? We have an issue with submitting things in a TAG based scenario {tag}{/tag}. The reason it has not been fixed is because it requires a bit of work.
12 years 10 months ago - 12 years 10 months ago #146984 by Jiminimonka
coder4life wrote: Out of curiosity, is this the only text you are submitting to the form. Is there no alternate text being inserted outside the brackets? We have an issue with submitting things in a TAG based scenario {tag}{/tag}. The reason it has not been fixed is because it requires a bit of work.
@coder4life - I have found this to happen sometimes. You can't have just the tags and no text, there has to be something else in the post or it won't allow you to save it.
@DarKMaSk - Make sure you have some text in the post you make and see if it works then.
Last edit: 12 years 10 months ago by Jiminimonka.
