Solved Birthday shows as day prior
12 years 10 months ago - 12 years 10 months ago #146670 by sozzled
Replied by sozzled on topic Birthday shows as day prior
Don Foster wrote: 1. Kunena - Kunena change was from "1" to "1". Should that have been "1"to "0"?
I meant 1 -> 0, yes. I corrected the typo in my earlier reply (and the duplication of that typo on Jiminimonka's reply to you, too.
Don Foster wrote: 2. Which menus do you mean? I added some menus into the stock Kunena menu (2 admin function menus and 1 copy of a help menu). you want me to remove those? or did I misunderstand?
I mean, trash every menu item that you have - whatever was installed originally and anything you've "customised" - for Kunena, permanently empty the trash, and then re-create the standard menu using the Kunena tools in the admin. dashboard Let's get back to basics and let's see a basic config. report soon. Then we can proceed further with our diagnosis. OK?
Last edit: 12 years 10 months ago by sozzled.
12 years 10 months ago - 12 years 10 months ago #146708 by Don Foster
ok. Have made settings to plugins as requested.
As I'm a bit nervous about screwing up something, let me recap what I believe you want me to do.
1. Go to Menu Manager in Joomla.
2. Select Forum menu item and permanently remove it be selecting Trash (and thus any submenu items will be deleted).
3. Purge trash.
4. Go to Dashboard and select Tools.
5. Click Menu Manager.
Now I'm guessing something will be different once I have removed my menus, because currently what I see is a screen that shows the status of the menus and shows no conflicts and that's it - no option to rebuild menus. Correct?
Confused because video showed Trash while mine shows restore option.
Sorry for the delay on getting you the updated config report. I want to be sure I do this right, before I screw it up worse.
Thanks.
Last edit: 12 years 10 months ago by Don Foster.
12 years 10 months ago #146709 by Jiminimonka
Always make a backup of your site before making major changes.
Your recap is correct.
Please read the FAQ.
Only one question per topic.
The following user(s) said Thank You: Don Foster
12 years 10 months ago #146718 by Don Foster
Ok. Completed. Here is the new report.
Eagerly awaiting help. :)
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 200M
Joomla default template details : | author: | version: | creationdate:
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.1 | creationdate: 2013-06-29
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Third-party components: AlphaUserPoints 1.8.3 | CommunityBuilder 1.9 | UddeIM 3.1
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
12 years 10 months ago #146722 by sozzled
Looks better but I would still remove the extra menu item ID=571 and empty the trash.
Your forum is currently "Offline for maintenance". It is difficult to see the problem as you see things through your own eyes without a test account for us to experiment with. Do you have a test account for using your forum? You can provide us with details using the
12 years 10 months ago - 12 years 10 months ago #146724 by Don Foster
Sorry.forgot about that menu item.
Removed and trash emptied.
User info:
I think that should work.
Time to create page: 0.284 seconds
