Solved Birthday shows as day prior
12 years 10 months ago #146373 by Don Foster
Hello.
Have looked through the forum, but can't find anything (besides the module) dealing with birthday issues.
I'm having an odd issue. Inputting DOB (birthdate) into the Kunena profile shows as one day prior (i.e. inputting 02/02/2013 displays in profile as 02/01/2013)
Any ideas?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 200M
Joomla default template details : | author: | version: | creationdate:
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.1 | creationdate: 2013-06-29
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Third-party components: AlphaUserPoints 1.8.3 | CommunityBuilder 1.9 | UddeIM 3.1
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
12 years 10 months ago - 12 years 10 months ago #146381 by sozzled
Replied by sozzled on topic Birthday shows as day prior
It's my guess that one of two things is involved here.
(a) Your Joomla Global Configuration settings use the a different or the "wrong" timezone to the timezone that your users use ; or
(b) Your personal forum preferences use a different timezone to the setting in your Joomla Global Configuration.
Last edit: 12 years 10 months ago by sozzled.
12 years 10 months ago #146648 by Don Foster
sorry for the slow response.
just got back from vacation.
I've checked all of the timezone issues - they all show as Chicago (where I am).
I've made test users and input their DOBs but all are incorrect.
Any ideas?
12 years 10 months ago - 12 years 10 months ago #146651 by sozzled
Let's see what we can do to clean things up:
Look at your integration plugins (see below):
Kunena - AlphaUserPoints Enabled: activity=1 avatar=0 profile=0 activity_points_limit=0
Kunena - Community Builder Enabled: access=1 login=1 activity=1 avatar=1 profile=0 private=0
Change them to these values:
Kunena - Community Builder Enabled: access=0 login=1 activity=0 avatar=1 profile=0 private=0
Kunena - Kunena Enabled: avatar=0 profile=1
Next, trash and delete all your menu items that relate to Kunena and use the default Kunena menu. See Kunena Menu issues in the Wiki to find out how to do that. After that, let's see your configuration report again.
Last edit: 12 years 10 months ago by sozzled. Reason: Corrected typo
12 years 10 months ago #146660 by Don Foster
thanks for the quick response.
Couple of questions first.
1. Kunena - Kunena change was from "1" to "1". Should that have been "1"to "0"?
2. Which menus do you mean? I added some menus into the stock Kunena menu (2 admin function menus and 1 copy of a help menu). you want me to remove those? or did I misunderstand.
thanks
12 years 10 months ago - 12 years 10 months ago #146667 by Jiminimonka
Make sure you backend settings match what Sozzled has posted in the second half of that message.
Please read the FAQ.
Only one question per topic.
Time to create page: 0.300 seconds
