Question Upgraded to K 3.0.0 but "preview' button does not display message preview
13 years 3 months ago - 13 years 3 months ago #146257 by stitchva
Oh Yeaah! Just wished to make a backup, install it locally just to be able to discart the issue could not be server config. related.
>> Installed locally and the issue is still there.
htaccess: Exists | PHP environment: Max execution time: 660 seconds | Max execution memory: 512M | Max file upload: 360M
Joomla default template details : sv2 | author: John Wright | version: 1.0 | creationdate: Unknown
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Third-party components: CommunityBuilder 1.9
Plugins: None
>> Attached local server PHPInfo
Thanks again for attention,
Last edit: 13 years 3 months ago by sozzled. Reason: Reveal Kunena configuration report in message
The topic has been locked.
13 years 3 months ago #146296 by xillibit
Do you have tried to look what message are displayed firebug console when you are using preview feature ?
13 years 3 months ago #146297 by sozzled
stichva: you are using the old Blue Eagle template designed for K 1.7.2. Try using the one designed for K 3.0, instead.
Also, please read Support for PC-hosted websites (e.g. WAMP, XAMPP) .
13 years 3 months ago - 13 years 3 months ago #146308 by stitchva
xillibit wrote: Do you have tried to look what message are displayed firebug console when you are using preview feature ?
Yes of course, but not red warnings for both website versions (live one and local one). Even through Google Chrome inspect feature = no red warnings.
Enabled Blue Eagle 2.0 as the default template on both website version (live one & local copy running over Joomlas2Go! 5.07 MULTISITE Pack)
sozzled wrote: - Also, please read Support for PC-hosted websites (e.g. WAMP, XAMPP) .
Joomlas2Go! 5.07 has its UwAMP built-in server very well tweaked to meet Joomla! requirements, however, I'm doing every step test over the same site hosted live & local each time before posting an answer here,
Reported issue still there (preview feature still not shown)
I'll try to rebuilt the site (locally) starting from Joomla! + Kunena and testing the reported issue functionality right after installing / enabling every other component, module and single plugin...
If you see any other way to debug where is the conflict, please, let me know it!
Thanks both for your help and close support
Rgrds,
Last edit: 13 years 3 months ago by sozzled. Reason: Formatting changes to improve readability
13 years 3 months ago #146310 by sozzled
stitchva wrote: [
Joomlas2Go! 5.07 has its UwAMP built-in server very well tweaked to meet Joomla! requirements, however, I'm doing every step test over the same site hosted live & local each time before posting an answer here.
That's a lot of double-handling isn't it? Remember, you are not comparing apples with apples. The environment on your local server is nothing like the environment in the hosted platform. You may think that everything works on your local server but, when it comes time to deploy the site on the live production environment things work differently. Then we get the question "Why doesn't my site work on my production environment after I spent months working on it using a PC-based server environment?" Well, I think you would have to understand why we would have no ideas about such things.
We don't know what's happening on your local PC server environment. That's something only people on your LAN can assist you with. Good luck with the resolution. We will mark this topic as unsolvable and move it to the archive for you. If the situation changes, please let us know.
13 years 3 months ago #146311 by stitchva
Why to archive it? How to post final resolution here if marked as unsolvable and archive it?
Time to create page: 0.147 seconds
