Question Upgraded to K 3.0.0 but "preview' button does not display message preview
Isn't this what you wanted? You wanted us to close the topic, yes?stitchva wrote: Thanks both for your help and close support.
If you find a way to resolve your problem then, by all means, please post your solution.
We cannot help you if you continue to ask about issues that arise on your PC-hosted environment. Those are issues that can only be looked at by people who have access to your LAN. Therefore, in cases like these, where people ask for help with questions about their PC-hosted environment where they are unable to resolve them, we have to mark such issues as "unsolvable" until, or unless, the person asking the problem finds a solution. That's just the way things work at this forum.
The topic remains archived and "unsolvable" until you find a way to resolve this yourself or unless we can see the issues for ourselves by seeing your real configuration report together with a test account that allows us to reproduce the symptoms of this problem.
>> close support = does not mean that I have asked you to "close' the ticket. Please, 'Google Translate' the word close to your mother language to see that 'close' word has more than one meaning
>> I don't think the final site owner will allow me to give temp. SU access to their site. If yes, I would report you back the login data. However, I'll post here the conflict origin and final solution that surely may help others.
Thanks again for all,
Rgrds,
We do not require super-user access to see the symptoms of the "preview button problem". Any non-privileged account that is able to post messages on your site will do just as well. You have to understand that the problem can only be seen by someone who is looking at the site through your eyes. The rest of us are working blind but doing our best to help you. This topic remains marked as unsolvable and archived unless the operational constraints that you have imposed change.
We are unable to provide you with devoted, dedicated or sustained support in this situation. Yes, I did misunderstand what you meant earlier but, unless you provide us with the configuration details of your production site, the only people who can assist you with your current problems (on your LAN-restricted, PC-hosted environment) are the people who have access to your LAN.
>> Understood 1st. time you said that. Thanks anyway, to rewrite that several times.
>> Thanks for making more clear what type of access you would need. As said, if the final site owner would allow me to give 'frontend' access through a temp. 'member account' to their site forum then, I would report you back the login data.
Meantime, thanks again for all your attentions and close support,
Rgrds,
Tryed several approach to try to solve the reported issue but this one solved the reported 'upgrading' issue:
- Downloaded a backup of the live site.
- Restored to a Joomlas2Go! 5.10 MULTISITE Pack.
- Uninstalled 'Kunena 3.0.1' (the kunena DB tables remain there)
- Installed Kunena 3.0.1 as new
>> Reported 'Post preview not displayed' issue, has been solved.
- Backed-up again and replaced the 'wrong' live site version.
>> Hope this may help others,
Rgrds,
