Question Email Notification Not Working
13 years 5 months ago #145690 by vscire
I turned on the debug mode and tested another post and reply. The only message I get is "Warning: Kunena Debug Mode has been turned on!" However, maybe information appears in a spot that I'm not seeing. I did change some of the configuration earlier today, and now an administrator does not need to approve posts.
There are plugins that are Kunena plugins that are not enabled. Could that be my problem?
Kunena - AlphaUserPoints Integration
Kunena - JomSocial Integration
Kunena - Community Builder Integration
Kunena - Gravatar Integration
Kunena - UddeIM Integration
The topic has been locked.
13 years 5 months ago - 13 years 5 months ago #145691 by sozzled
Do not enable plugins that you do not need (especially those integration plugins). If you want to know more about what these things do, see Forum integration with other Joomla extensions
After enabling Kunena debug mode and submitting a new post in a topic to which other users are subscribed, you should see (at the bottom of the screen) further details about what happened when Kunena processed the submit request. Do you see any information about what happened?
Changing the configuration (without knowing what you are doing) - "experimenting" as it were - can be a dangerous thing that only further complicates matters. Reverting to the default configuration may be a better option and the first step to diagnosing what's going on. As I have written numerous times on this forum, Kunena should work, first time, out-of-the-box with no modifications needed to the configuration.
In cases where you want to test if email notifications are working, make sure that the forum email address (in the Kunena configuration) matches the site email address. This may be the only change that you need to make (see Subscription Emails are not working
Last edit: 13 years 5 months ago by sozzled.
13 years 5 months ago #145704 by vscire
With Debug turned on I don't see messages on any pages except the warning that it is turned on.
I used the feature to return the configuration to the default settings and that did not solve the problem.
The email address I use is a gmail account, so I created an account at HostGator using the Cpanel as mentioned in the thread for which you sent me a link. I changed the Global Settings in Joomla to the new email server at HostGator. Unfortunately, I got the same result. Emails are sent to the administrator, but not the creator of the original post for which there was a reply created.
Is there a method to uninstall Kunena and re-install? Maybe starting over is the solution?
13 years 5 months ago #145716 by sozzled
I have asked the developers to look into this matter about what happens when messages need to be approved by a moderator/administrator and email notifications are not sent after the message has been approved. It is possible that email notifications may not be sent (after the approval is made). This part of email notifications (where message review/approval is involved) may not have been tested and it is possible that the email feature may not work if message review/approval is involved.
We do not use message review at this website ( www.kunena.org ) because we do not feel that it is needed here and therefore I, personally, have not tested this feature. I have asked, a couple of times, for the developers to look at this matter and give you their considered response to your question. You could be right. This feature may not work if message review is used on a person's forum. I do not know any more than this. Sorry.
It's easy to uninstall and re-install Kunena if you think it would help. Before doing that, however, can we eliminate the possibility that message review/approval is a factor in preventing email notification to subscribed users?
13 years 5 months ago #145728 by vscire
Thanks for your continued attention to my issues. I have tested the situation with the forum set up so that approvals of posts are not required and I still have the email problem. I will try to uninstall and re-install.
13 years 4 months ago #145794 by Matias
Reinstalling Kunena doesn't help, I'm suspecting that there's a bug somewhere (my quick look into the code didn't reveal it, though).
Let's try to summarise the issue and try to figure out when emails get send and when they're not sent.
I would try these use cases:
* Category which doesn't need approvals
* Category which needs approvals
In both of them:
* Make one user as a moderator
* Make one user as a subscriber to the category
* Make one user as subscriber of individual topic
Then do these actions as yet another user (user himself doesn't get emails):
* Post a new topic (both categories)
* Reply to existing topic with subscriber in it (both categories)
* Approve both topic and message as moderator (moderated category)
All of these actions should send emails to someone. Which ones don't?
