This category is for discussing issues with the K 3.0 Blue Eagle template.
Question Borders missing from tabs in Kunena profiles (Blend with Joomla = Yes)
12 years 3 months ago - 12 years 3 months ago #153988 by sozzled
GT3 wrote: I think this is a bug because it doesn't matter what Joomla! template I use, on either 2.5 or 3.2 the problem is there.
What do you mean that you think this is a bug? If you choose the "blend with Joomla" option in the Blue Eagle template, this means that you effectively throw away most of the formatting styles that are used in the Blue Eagle template. You are simply exercising your freedom to choose.
I would not describe the absence of borders around <DL> or <DT> elements as a "bug". These HTML elements are not normally bordered.
If you want bordered "tabs" you can use the Blue Eagle template with the option Blend with Joomla = No
... or ...
If you use Blend with Joomla = Yes, you can add extra CSS rules to your Joomla site template to make it the Blue Eagle template look however you would like it to look. Despite what people may write, we do not recommend making changes to any of the original Kunena source files ... including the file ../components/com_kunena/template/blue_eagle/css/kunena.forum-min.css. Instead of making the changes suggested by Pinkeltje to that file, try adding those lines of CSS to the end of your Joomla site template instead. ;)
There is also another option: you could write your own Kunena template from scratch! ;)
Last edit: 12 years 3 months ago by sozzled.
Time to create page: 0.237 seconds
