Kunena 6.4.13 Released
This category is for discussing issues with the K 3.0 Blue Eagle template.
Question Borders missing from tabs in Kunena profiles (Blend with Joomla = Yes)
12 years 5 months ago #153932 by GT3
Good Morning,
I have a problem with the Tabs in the User Profile section of Kunena disappearing. It doesn't matter what template I use, but whenever I select "Blend with Joomla Template" from the Template Manager in Kunena, and then go to the User's profile, the tabs have disappear, but the text and links are still there.
Is it easy to get them back?
Many thanks, Steve :)
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : purity_III | author: JoomlArt.com | version: 1.0.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Third-party components: UddeIM 3.3
Plugins: None
12 years 5 months ago #153962 by GT3
12 years 5 months ago #153969 by 9themestore
Hi GT3,
I can help you check this issue but I think you should provide me a test account.
Regards
12 years 5 months ago #153976 by GT3
Thank you for your offer of help! :) Here's a test user account for you;
test.msalof.com
Username:User
Password: qwerty
Please let me know when have finished using it and I will delete it.
Many thanks
Steve
12 years 5 months ago #153982 by Pinkeltje
One solution is to add !important to border in components/com_kunena/template/blue_eagle/css/kunena.forum-min.css
#Kunena dl.tabs dt { border-left: 1px solid !important; border-right: 1px solid !important; border-top: 1px solid !important; float: left; margin: 0; padding: 4px 6px; }
12 years 5 months ago #153984 by GT3
Pinkeltje wrote: One solution is to add !important to border in components/com_kunena/template/blue_eagle/css/kunena.forum-min.css
Hello Pinkeltje,
Thanks for your post, yes that does work - but looks rather crude. Is there a way I can give these tabs the same styling as the others on the Profiles change?
I think this is a bug because it doesn't matter what Joomla! template I use, on either 2.5 or 3.2 the problem is there..
Thanks for your help! :D
Time to create page: 0.405 seconds
