Merged [Merged topic] K 2.0: Problems with third-party content plugins
14 years 4 months ago - 14 years 4 months ago #128197 by lutheriah
Hello! All of the events (plugins) already are activated. But the JoomLatex still doesn't work. I saw here in the forum that a user fixed the same problem activating the ancient function Joomla Content Plugin Support, existing in the Frontend Kunena administration tab. But in the Kunena 2.0 this function doesn't exist anymore.
I noticed that if I use the tags {tex}{/tex} of JoomLatex on topics, instead of equation appear in LaTex format, the following code appears:
<img src="latex.codecogs.com/gif.latex?x%20%3D%202%20%2B%203" title="x = 2 + 3" alt="x = 2 + 3" style="vertical-align: middle; margin-left: 1em;" />
If I use the tags in the Category Header or Description, the tags have no effect.
Last edit: 14 years 4 months ago by lutheriah.
14 years 4 months ago #128200 by 810
Are you using J2.5.x then go to administrator/index.php?option=com_plugins&view=plugins&filter_folder=system
click on System - Kunena Forum ->
Joomla Content Plugin Support to yes
regards 810
The following user(s) said Thank You: lutheriah
14 years 4 months ago - 14 years 4 months ago #128204 by lutheriah
Thanks for the answear! The system plugin already is set up to "on". And, if I choose "...bodies", on topics appears:
If I choose "...Titles", appears:
{tex}x = 2 + 3{/tex}
:unsure:
14 years 4 months ago - 14 years 4 months ago #128207 by sozzled
There are four important points that we need to make about the matters discussed in this topic:
(1) All of the problems that people have reported relate to content plugins, developed outside Kunena, that people have installed themselves;
(2) These content plugins were developed by third-party developers for versions of Kunena before K 2.0.x. The K 2.0.x release notes clearly state the following This important point also appears in Before you post your question, read this first . People should read the release notes and the sticky topics in this forum so that they understand what may be the reason for their problems.
(3) There was an issue with the System - Kunena Forum plugin in K 2.0.0 which has been fixed in K 2.0.1.
(4) Third-party content plugins will not work unless they are
  • compatible with K 2.0; and
  • you have enabled the System - Kunena Forum plugin (see the image below):
Last edit: 14 years 4 months ago by sozzled.
14 years 4 months ago - 14 years 4 months ago #128215 by lutheriah
The system plugin already is set up to "Yes". And, if I choose "...bodies", on topics appears:
:unsure:
14 years 4 months ago #128217 by sozzled
lutheriah: Have you discussed this issue with the person who developed the JoomLatex content plugin to ensure that their plugin was compatible with K 2.0.1? From what I see at the JED , JoomLatex was last updated in April 2010 and it doesn't look as if this is supported any more.
