Question [Merged topic] How to maintain Gender, Birthday... and other Kunena fields - with CB integration?
14 years 6 months ago #120662 by lucablue
Yxos wrote:
sozzled wrote: Set Forum Configuration » Integration » Integration Options » Profiles and User List = Kunena.
You can now easily change the gender icon, location, birth date and other things used in the forum.
Yes, but I am afraid that is what we don't want. We deliberately set Profiles and User List = Community Builder because we wanted the integration to CB, and thats where the problem lies.
THIS!
How can report icon of gender, birthday and so on using Community Builder Profile???
14 years 6 months ago #120917 by Paladin Brewer
htaccess: Missing | PHP environment: Max execution time: 50000 seconds | Max execution memory: 90M | Max file upload: 40M
Joomla default template details : rt_dominion_j15 | author: RocketTheme | version: 1.5.13 | creationdate: October 21, 2011
Kunena default template details : nts_kdark | author: 9ThemeStore | version: 1.7.0 | creationdate: 2011-05-07
Third-party components: CommunityBuilder 1.8 | UddeIm 2.5
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | Kunena Search 1.7.0
Modules: Kunena Latest 1.7.0 | Kunena Stats 1.7.0 | Kunena Search 1.7.0
Hello. I use Kunena and also Community Builder, and I use CB's profile. I upgraded both Kunena and CB. Now Gender on the forum displays as "Unknown," however it worked fine before upgrades. I was wondering if the upgrade to Kunena 1.7.2 would have made any changes that might effect this.
14 years 6 months ago #120918 by sozzled
You can change the gender by changing your Kunena user profile. However, because you are using Community Builder for your user profiles, you need to find a way to create a CB gender field and map it to Kunena. This is more of a CB issue than a Kunena issue but it's not really too difficult to do.
You can map the CB website and CB location fields to Kunena. Your issue is given more treatment in Cannot integrate CB custom fields to Kunena using cb.simpleboardtab plugin .
Alternatively, you can set Forum Configuration » Integration » Integration Options » Profiles and User List = Kunena.
Sometimes the choices to use certain kinds of user profiling systems (e.g. Community Builder, or AlphaUserPoints or JomSocial) have extra costs involved in order to make your forum as "fully functional" in areas such as this one. I hope some of this helps you.
The following user(s) said Thank You: Yxos
Time to create page: 0.268 seconds
