Question [Merged topic] How to maintain Gender, Birthday... and other Kunena fields - with CB integration?
15 years 5 hours ago - 15 years 5 hours ago #108354 by Yxos
If you run Kunena with Community Builder (CB) integration, then Kunena takes you to the CB profile instead of the Kunena profile.
This of course means that no users are able to maintain standard Kunena profile fields like Gender, Birthey etc. Instead you may maintain a selection of CB user fields of your own choice.
The problem is that the sidebar i Kunena forum shows these fields; or it tries to. The result is that everybody appear as "no gender" and so on - because there is no way the user can maintain these fields.
The question was up before, and sozzled answered it this way...:
sozzled wrote: www.kunena.org/forum/12-community-builde...icons-in-forum#99028
You can change the gender by changing your Kunena user profile. However, because you are probably using Community Builder for your user profiles, you need to find a way to create a CB gender field and map it to Kunena. This is more of a CB issue than a Kunena issue but it's not really too difficult to do...
I REALLY would appreciate if somebody did this, and can explain how to, because I don't find particulary easy... :dry:
I run Joomla 1.7 with CB 1.7.1 and Kunena 1.7.0.
/Yxos, Kunena Translator, da-DK.
Overvej at abonnere på kategorien www.kunena.org/forum/48-Danish
Last edit: 15 years 5 hours ago by Yxos.
14 years 9 months ago - 14 years 9 months ago #112997 by s3ph1roth
I've run into the same problem today, but it's been a fairly easy one to overcome.
First off, begin by creating as many Community Builder fields as you need. I personally have made 2, a "date" field called "Birthday" and a Gender field basing myself off the first 2 points given in this post www.joomlapolis.com/forum/146-general/15...nder-specific-avatar
Now, get in the Plugin Management tab of CB. Look for the "Forum integration" plugin and edit it.
In the parameters, set "Forum component" as "Kunena", of course.
As "Sidebar Mode", choose "Beginner". You'll see a load of new fields popping up, taken directly from your Kunena profiles. Here you can choose the CB fields to redirect them to.
Simply select your previously created Birthday field for Birthday, and so on. You can even make new fields for MSN/Yahoo/Facebook and all of the others.
The fields can be normally modified in the CB profile, and will now correctly show up in the Kunena forum as icons ;)
Last edit: 14 years 9 months ago by s3ph1roth.
The following user(s) said Thank You: Yxos
14 years 6 months ago - 14 years 6 months ago #119789 by lucablue
I've created into Community builder the param cb_gender to specify as radio button to make the choice Male or Female.
But near the posts of my users appear "no specified" under the icon of gender. How can I resolve this issue?
The same with the icon of birthday... no icon for birthday under the avatar into the forums
Last edit: 14 years 6 months ago by lucablue. Reason: OPS... sorry, I've put it in a wrong thread... can you move it for me?
14 years 6 months ago #119986 by Yxos
sozzled wrote: Set Forum Configuration » Integration » Integration Options » Profiles and User List = Kunena.
You can now easily change the gender icon, location, birth date and other things used in the forum.
Yes, but I am afraid that is what we don't want. We deliberately set Profiles and User List = Community Builder because we wanted the integration to CB, and thats where the problem lies.
14 years 6 months ago - 14 years 6 months ago #120599 by fribse
I'm trying to make kunena show the right fields in the sidebar profile in kunena.
It keeps showing 'Køn: ukendt' (Gender: unknown).
I've set the field in the CB plugin to point to the right field in CB.
No matter what I set up in the CB plugin, it shows the same, and it keeps showing the gender icon, even if I set it to 'select field' in CB.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : themza_j16_01 | author: Themza Team | version: 1.6.0 | creationdate: 07 May 2011
Kunena default template details : DKDB | author: Dykkerklubben Dannebroge | version: 1.0 | creationdate: 2012-03-06
Third-party components: CommunityBuilder 1.8 | UddeIm 2.6
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.7.1
Modules: Kunena Latest 1.7.1 | Kunena Stats 1.7.1
Best regards
Fribse
Dykkerklubben Dannebroge www.dkdb.dk
We're a volunteer driven diving club in Mosede, Denmark.
Har du brug for en dykkerklub der rummer alle, så kom ned til os.
Last edit: 14 years 6 months ago by fribse.
Time to create page: 0.238 seconds
