- Thank you received: 4
Question [Merged topic] How to maintain Gender, Birthday... and other Kunena fields - with CB integration?
This of course means that no users are able to maintain standard Kunena profile fields like Gender, Birthey etc. Instead you may maintain a selection of CB user fields of your own choice.
The problem is that the sidebar i Kunena forum shows these fields; or it tries to. The result is that everybody appear as "no gender" and so on - because there is no way the user can maintain these fields.
The question was up before, and sozzled answered it this way...:
I REALLY would appreciate if somebody did this, and can explain how to, because I don't find particulary easy... :dry:sozzled wrote: www.kunena.org/forum/12-community-builde...icons-in-forum#99028
You can change the gender by changing your Kunena user profile. However, because you are probably using Community Builder for your user profiles, you need to find a way to create a CB gender field and map it to Kunena. This is more of a CB issue than a Kunena issue but it's not really too difficult to do...
I run Joomla 1.7 with CB 1.7.1 and Kunena 1.7.0.
/Yxos, Kunena Translator, da-DK.
Overvej at abonnere på kategorien www.kunena.org/forum/48-Danish
First off, begin by creating as many Community Builder fields as you need. I personally have made 2, a "date" field called "Birthday" and a Gender field basing myself off the first 2 points given in this post www.joomlapolis.com/forum/146-general/15...nder-specific-avatar
Now, get in the Plugin Management tab of CB. Look for the "Forum integration" plugin and edit it.
In the parameters, set "Forum component" as "Kunena", of course.
As "Sidebar Mode", choose "Beginner". You'll see a load of new fields popping up, taken directly from your Kunena profiles. Here you can choose the CB fields to redirect them to.
Simply select your previously created Birthday field for Birthday, and so on. You can even make new fields for MSN/Yahoo/Facebook and all of the others.
The fields can be normally modified in the CB profile, and will now correctly show up in the Kunena forum as icons
I've created into Community builder the param cb_gender to specify as radio button to make the choice Male or Female.
But near the posts of my users appear "no specified" under the icon of gender. How can I resolve this issue?
The same with the icon of birthday... no icon for birthday under the avatar into the forums
Yes, but I am afraid that is what we don't want. We deliberately set Profiles and User List = Community Builder because we wanted the integration to CB, and thats where the problem lies.sozzled wrote: Set Forum Configuration » Integration » Integration Options » Profiles and User List = Kunena.
You can now easily change the gender icon, location, birth date and other things used in the forum.
It keeps showing 'Køn: ukendt' (Gender: unknown).
I've set the field in the CB plugin to point to the right field in CB.
No matter what I set up in the CB plugin, it shows the same, and it keeps showing the gender icon, even if I set it to 'select field' in CB.
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : themza_j16_01 | author: Themza Team | version: 1.6.0 | creationdate: 07 May 2011
Kunena default template details : DKDB | author: Dykkerklubben Dannebroge | version: 1.0 | creationdate: 2012-03-06
board_offline 0 board_ofset 0.00 enablerss 1 enablepdf 0 threads_per_page 20 messages_per_page 10 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template dkdb showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 0 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 300 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 0 allowavatar 1 allowavatarupload 0 allowavatargallery 0 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 500 allowfileupload 0 allowfileregupload 0 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 500 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 0 userlist_name 1 userlist_username 0 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 0 userlist_lastvisitdate 1 userlist_userhits 0 latestcategory 0 showstats 0 showwhoisonline 0 showgenstats 0 showpopuserstats 0 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 11 help_infb 1 help_cid 10 showspoilertag 0 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 1 sefutf8 0 showimgforguest 1 showfileforguest 0 pollnboptions 10 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 24:0:00 pollnbvotesbyuser 10 pollresultsuserslist 1 maxpersotext 150 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access joomla integration_login none integration_avatar communitybuilder integration_profile communitybuilder integration_private uddeim integration_activity none boxghostmessage 0 userdeletetmessage 1 latestcategory_in 1 topicicons 1 onlineusers 0 debug 0 catsautosubscribed 0 showbannedreason 1 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 1 bbcode_img_secure text listcat_show_moderators 0 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 1 show_session_starttime 0 userlist_allowed 1 userlist_count_users 1 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 0 thankyou_max 10 email_recipient_count 0 email_recipient_privacy bcc email_visible_address captcha_post_limit 0
Third-party components: CommunityBuilder 1.8 | UddeIm 2.6
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.7.1
Modules: Kunena Latest 1.7.1 | Kunena Stats 1.7.1
Best regards
Fribse
Dykkerklubben Dannebroge www.dkdb.dk
We're a volunteer driven diving club in Mosede, Denmark.
Har du brug for en dykkerklub der rummer alle, så kom ned til os.
