Question Translators request
16 years 3 months ago #52770 by alakentu
Replied by alakentu on topic Re: Translators request
@iLucato.
First you download the copy that I posted regarding your own language (pt-BR), then you edit it the way that points in the image, you should not override the gb-GB file, only your language.
It must be saved in UTF-8 (the will review anyway ;))
Once you have published please send them to the email address I have mentioned to take care of everything else. In due course will be known as installation and/or update to K1.6.
At the moment the official support is for K1.5.12 (latest version) K1.6 this stage ALPHA (official). Now we will give complete information about K1.6 when this sees the light of day in his stable.
I recommend Winsintax is very versatile and very handy, not much to configure and you can edit the php file in UTF-8.
The firm can add to your profile by editing your profile, go to the tab "Community" and then select "Forum Settings" but as you have said ... That is another issue.
Thanks and best regards.
KS!
NO hacer Spam | NO esbribas todo en mayúsculas | Sigue las reglas
16 years 3 months ago #52771 by alakentu
lavsteph wrote: Hello,
my trick for translations, to be sure to have the same structure as the English files, a file comparison software is very useful, for example Meld with Ubuntu or Winmerge for Windows.;)
Thanks, I find it interesting, it proved to see how it works.
KS!
16 years 3 months ago #52776 by lavsteph
Replied by lavsteph on topic Re: Translators request
Once the conversion completed, it will compare each line to be closer to the base files, then it's a breeze for new versions.
we note the differences and is corrected quickly to have the same lines as in the base file.
Manager French translation
16 years 3 months ago #52802 by Cerberus
Replied by Cerberus on topic Re: Translators request
i use winmerge alot myself for all aspect of comparing css and php files
16 years 3 months ago #53408 by iLucato
Replied by iLucato on topic Re: Translators request
alakentu wrote:
  • Portuguese (Brazil) Translation pt-BR
  • Hey Alakentu, in the ZIP file I got two folders they are:
    1) Folder 'admin' with the files pt-BR.com_kunena.ini and pt-BR.com_kunena.install.ini;
    2) Folder 'site' with the file pt-BR.com_kunena.ini
    Once they have similar names and we have a few folders called 'language' I wonder where should I move each file from folder 1 and 2 to wich specific folder/patch?
    Thanks in advance
    16 years 2 months ago #55812 by rued
    Replied by rued on topic Re: Translators request
    Please note! Those who want the Component menu translated i Joomla! 1.5 Adminsitration should add an extra file for Joomla! language folder in administration.
    Path/Name: /administrator/language/xx-XX/xx-XX.com_kunena.menu.ini
    Content can be something like (to be translated):
    ; $Id: xx-XX.com_kunena.menu.ini 1259 2010-08-10 12:50:34Z svnuser $ ; License GNU General Public License version 2 or later; see LICENSE.txt, see LICENSE.php ; Note : All ini files need to be saved as UTF-8 - No BOM ; Translations for Joomla! 1.5 Component Menu ; Translator comments come into here! COM_KUNENA=Kunena COM_KUNENA.CONFIGURATION=Configuration COM_KUNENA.CATEGORY MANAGER=Category Manager COM_KUNENA.USER MANAGER=User Manager COM_KUNENA.EMOTICON MANAGER=Emoticon Manager COM_KUNENA.RANK MANAGER=Rank Manager
    The following user(s) said Thank You: valandis
