Question Problem in IE8
17 years 7 months ago - 17 years 7 months ago #9210 by Lintzy
Replied by Lintzy on topic Re:Problem in IE8
John wrote:
If an external image is added, IE8 shows the picture correctly 700 pics wide (maximum on my forum), however the forum gets wider to fit the original picture before downsizing. IE7 shows just fine.
Can be corrected by adding size=700 to te code but this has to be done manually.
URL: www.hobbykwekers.nl/component/option,com.../func,view/id,67/#85
Test the lightbox-plugin, perhaps, this fixes this problem.
www.kunena.com/forum?func=view&catid=20&id=7531
A question to IE 8: there is no standalone installation near IE7 possible, or?
Last edit: 17 years 7 months ago by Lintzy.
17 years 7 months ago #9216 by John
Replied by John on topic Re:Problem in IE8
I have 1.5 and Mootools active (needed for my template).
IE8 replaces IE7, cant have them both at the same time.
17 years 7 months ago #9219 by Lintzy
And you have no lightbox effect?
17 years 7 months ago - 17 years 7 months ago #9220 by John
Hmmmm...no? thats not good...
Adding: JHTML::_('behavior.mootools'); to the index.php in my template directory doesnt help. (in IE8 got to check 7).
In IE7 it just looks fine. When moving mouse over an image it shows a hand. When clicking it, the windows shows only the photo in full resolution. The same in IE8.
Last edit: 17 years 7 months ago by John.
17 years 7 months ago #9230 by Lintzy
I have a lightbox effect, pls look at my posted link, there were some problems called and how to fix them, issues with more other scripts and so on.
17 years 7 months ago - 17 years 7 months ago #9234 by John
Ok, I installed YOOeffects Plugin and have lightbox effects. Working great in IE7 and IE8, but still IE8 makes the forum too wide.
ps. thanx for the link.
