- Thank you received: 4
Question Problem in IE8
Browsercache deleted?
oh :blush: forget it.... i looked with firefox :blush:
And i could fix it for IE6 and therefore, this css-hack is important to many Kunena-Admins, because many user still are using IE6.
Next problem was to find a CSS-Hack for IE8. I don't know, if this CSS Hack is working, so please tell me, when the fix solved the oversized Forum.
Edit the kunena.forum.css (of your used Template!) and put these lines of code at the end of the css (this is important)
Maybe this is something to include in standard Kunena?
My websites: AquaInfo.org | AquaInfo.nl
Thank you very much! This solved the problem.
CSS-Hacks and Conditional Comments only work, when the user agents of the browsers show: "Hi, I am IE 6" and so on. Most of them do, a few don't do so. F.e. Opera seems to be a IE.
And with every browser-update it can happen, that your fix don't work anymore. It'a pity, because it can cause many problems for webdesigner with their clients. But on the other side, sometimes those hacks are the only way, to fix such a problem.
You can put that code in CSS or other formated code in html. Best way of all is a browser switch, that links to an ie.css and an ie8.css and so on.
I don't know, if such hacks are something, the Kunena DEVs would implement into Kunena Core, but this should be answered through themselves.
Since a few days, I am working at a template for Kunena 1.08, with many core fixes and a browser-switch. But it is much work, i don't know, when it is finished.
